how much play should the shaft have ?
Old Mar 12, 2006 | 11:52 AM
Ben26's Avatar
Ben26
Default how much play should the shaft have ?
how much is the normal amount of play a turbo shaft should have ???
mine moves about 10mm up and down ??
is that good or bad ?
Ben
Old Mar 12, 2006 | 11:57 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
That's fucked I reckon. The shaft normally has minimal movement up and down, like a couple of mm at the most.
Old Mar 12, 2006 | 12:00 PM
Ben26's Avatar
Ben26
shit !!!
how would i go about gettin it reconed were and how much ??
Ben
Old Mar 12, 2006 | 12:01 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You should really only just be able to detect movement in any direction. The more movement it has, the more out of balance it will become, which will in turn make the movement worse!!
1-2mm at a guess, 10mm and the blades will have touched the housing, so perhaps consider popping that in the wheely-bin.
COSSIE 1's Avatar
COSSIE 1
mines got about 2-3mm but isnt hitting the housing but its making a slight whistling sound which is the air being disturbed from the outof balance shaft ......oh well....ill just fit the stage3 hybrid ive just bought
Old Mar 12, 2006 | 12:03 PM
Ben26's Avatar
Ben26
what would be worn then if it has that much play in it , the thrust bearing ?
Ben
Old Mar 12, 2006 | 12:09 PM
Tony Turbo's Avatar
Tony Turbo
That is why you should take the advice of the Turbo Bananananana
Old Mar 12, 2006 | 12:12 PM
Ben26's Avatar
Ben26
PMSL
Ben
Old Mar 12, 2006 | 12:28 PM
Christian and Beccy
#1 in Spelling Club
Old Mar 12, 2006 | 12:30 PM
COSSIE 1's Avatar
COSSIE 1
wtf
Old Mar 12, 2006 | 12:46 PM
Ben26's Avatar
Ben26
Ben
Old Mar 12, 2006 | 12:58 PM
David Ramsey's Avatar
David Ramsey
pmsl
Old Mar 12, 2006 | 02:45 PM
Dan's Avatar
Dan
Old Mar 12, 2006 | 03:57 PM
Tony Turbo's Avatar
Tony Turbo
Yes.................. Very witty
Old Mar 12, 2006 | 04:03 PM
yzfr1boy's Avatar
yzfr1boy
seen a couple of rebuilt ones on ebay today as mine had play just finished fitting it bought mine of ebay seems ok or you can buy the kits from turboforce . co.uk has any1 tried these rebuild kits?
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
rsstav
Sep 7, 2015 04:43 AM
ST-170
Sep 4, 2015 11:02 AM
