GRS coolers on S1
depends on how you want it looking
i trimmed a slight part by the headlight so it sat square and another little bit where the fan goes but you wouldnt of noticed it
ive now got a different fan so ive had to trim a bit more
Originally Posted by nigel b
Originally Posted by Tony Turbo
2 fans will be needed mate, not sure about fitting
1 does the job if you use the right type of fan
What makes an S1 cooling system better than an S2's?
It isn't any better as such to be honest Tony but there is the fact that the S1 doesn't have the turbo heating the coolant up. On that same token, the S2 has a slightly larger capacity cooling system.
its the effiency of the fans to deal with the temps
my single fan flows better than 2x10" fans so deals with the temps alot better
i used to use a single 10" but it wasnt powerful enough and i didnt want to use 2 fans
mine isnt as slim as a 10" kenlowe,but it is slimmer than the stock fan
im using the kenlowe 13" h/d fan but part of my front panel is missing now as it was too tight to fit
probably be ok in a s2?
