slick tyre size help
Im confused as fook by slick tyre sizes compared to road tyres so any of you tyre experts can you tell me the nearest slick sizes to the folowing
194/45/15"
and
195/40/16"
if they are different in size,how much bigger/smaller are they?
thanks for any help
194/45/15"
and
195/40/16"
thanks for any help
Well, AFAIK, slick tyres are sized in the following way.....
The first number is the width. They tend to be more of an accurate width than a road tyre. So, 190 = 190mm wide.
The second number is the overall diameter. So, 580 = 580mm diameter. A 195/45/15 is around 570mm diameter.
The third number is obviously the rim size. i.e. 15 or 16.
I don't think you will get anything close to the sizes that you state there though.
