what is your oil pressure??
Old Mar 11, 2006 | 07:06 PM
lammylama's Avatar
lammylama
Default what is your oil pressure??
just wondering what everyones oil pressure is on their cossies cold and hot on tickover and driving????????
Old Mar 11, 2006 | 07:11 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
What are yours ?
Cold = about 52
Hot idle = about 34
Hot driven = about 47-48
This is with a capilery gauge.
Steve.
Old Mar 11, 2006 | 07:16 PM
lammylama's Avatar
lammylama
mines as follows
cold idle.....70psi
hot idle.....20psi
hot driving....55-60psi
hope this is ok!!!!!!!
Old Mar 11, 2006 | 07:19 PM
rapidcossie's Avatar
rapidcossie
stone cold about 79
hot idle about 28
Old Mar 11, 2006 | 07:20 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I don't know why mine is so low on Hot driven ?
It has lost a few pound of pressure over 3 years but has never been high.
I think your Hot idle is a bit low, but not sure.
Steve.
Old Mar 11, 2006 | 07:21 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
OIL PRESSURE (ALL MODELS)
MINIMUM OIL PRESSURE WHEN AT NORMAL OPERATING TEMPERATURE.
IDLE SPEED 1.8 BAR (26 PSI)
2000 RPM 2.4 BAR (35 PSI)
FUEL PRESSURE (ALL MODELS)
IDLE SPEED 3.0 BAR (44 PSI)
WITH PRESSURE PIPE REMOVED FROM REGULATOR 3.5 BAR (51 PSI)
Old Mar 11, 2006 | 07:22 PM
lammylama's Avatar
lammylama
i thought the same about my hot idle too.....what does anyone else think??
Old Mar 11, 2006 | 07:23 PM
rapidcossie
your just a fountain of knowledge mike
lammylama's Avatar
lammylama
thanks for the info there mike
Old Mar 11, 2006 | 07:25 PM
dave cos4x4's Avatar
dave cos4x4
mines about 4.5 bar.
Old Mar 11, 2006 | 07:44 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So does this means my Hot Driving pressure is ok, was a bit concerned it was low.
Steve.
Old Mar 12, 2006 | 08:25 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
need to know if i have enough pressure to uprate the engine to 400s
Steve.
Old Mar 12, 2006 | 10:14 AM
The original oil pressure sender is set to show the oil light on when you hit 15psi.
If you showing 20psi at idle...not really a worry maybe your tick over is a bit low?
The main part is 2000rpm as Mike points out MUST be min 35psi.
My 2 Cossies have newish engines in the Escos has a high pressure pump and the Saff a std one.
Escos @ idle at 1000rpm tickover is 35 (will drop to 25 after a really hard thrash but its only running semi synthetic oil at the mo)...at cold its 70psi ish warm at 3000rpm 55psi
Saff @ idle at 700rpm on crap running in oil is 30psi ish on cold about 55psi and at 3000rpm around 50psi
Old Mar 12, 2006 | 10:15 AM
Cossie4i...your figures are fine for a std pump IMO
Old Mar 12, 2006 | 10:29 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thank the Lord lol
Karl and the 400s here i come
Steve.
Old Mar 12, 2006 | 01:05 PM
Mike Rainbird
Caraholic
Steve.
Are you stupid? . If your oil pressure exceeds the minimum required, then you have nothing to worry about . I thought that was pretty clear myself .
Old Mar 12, 2006 | 01:08 PM
YBP's Avatar
YBP
Warm tickover:
About 3bar (44psi) @ 900rpm
5.3bar (78psi) from just below 2k and up.
Cold:
5bar+ (74psi+) From tickover and up.
Just got to love the high capacity pump.
Old Mar 12, 2006 | 02:13 PM
There is no need at all for such high oil pressure....i bet your gaskets luv you!!!
Old Mar 12, 2006 | 05:27 PM
YBP's Avatar
YBP
My pump doesn´t make any higher pressure than the normal high pressure pump. It just makes more pressure at low rpm.
The high pressure at low rpm means my pistons loves me for getting nice cooling oilspray even at tickover.
Old Mar 13, 2006 | 12:21 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve.
No im not stupid Mike
Just like to make sure
Steve.
Old Mar 13, 2006 | 07:40 AM
Mike Rainbird
Caraholic
Old Mar 13, 2006 | 09:40 AM
costina's Avatar
costina
Live long and prosper!!
Don't forget that oil plays a big part .i find that castrol 10/60 gives a higher all round pressure,mobile 1 motorsport is a little lower .
My mate put comma oil in his and hot pressure was the worst (driving) at 35 psi @ 4000 rpm The oil did not stay in there long !!!!!
oil coolers can drop pressure as the pump needs to flow more .
Old Jun 3, 2006 | 03:07 PM
pee vee's Avatar
pee vee
My oil pressure is at 80 PSI at 3000 RPM (when at 80ish degrees)
im using 10-40 mineral oil to run it in,
is this gonna give me any probelms when i change to proper oil later on?
blowing seals out all over the show ?
Old Jun 3, 2006 | 05:01 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Got it back together again then
Just finished my bottom end rebuild as well last night
Got a standard pump in mine, hot idle is now 39-40 lbs
Steve.
Old Jun 3, 2006 | 05:12 PM
YBP's Avatar
YBP
Probably no, if it´s a high pressure pump. I think it´s the pressurerelief that opens to keep it at that pressure.
If it is a std. pump you might have a problem running thicker oil. Because 80psi on a std. pump means that the pressurerelief valve can´t get rid of enough excess oil to keep the pressure down. And this would get worse with thicker oil.
If everything is rebuilt with new stuff with the right clearences, you won´t get much more pressure with better/thicker oil.
If there is a huge difference, something is wrong. Only if the clearance in pump and/or bearings is too big you will get benefit of a thicker oil.
Old Jun 3, 2006 | 05:16 PM
pee vee's Avatar
pee vee
Standard size everything, everything within ford tolerances.
but with a high pressure pump.
seems to idle just below 30psi at 80degrees,
but as soon as you touch the throttle its
up round 60 and above.
thanks!
cossie4i
yes mate new crank and bits and pieces!
everything is almost exact same toleraces as before,
and yet the oil pump is the only thing thats been altered... they still reckon it wasnt fooked
just wanna drive it now!
SMILER258
Sep 28, 2015 09:04 AM
