rst engine Q
Old Mar 11, 2006 | 12:03 PM
the saint's Avatar
the saint
Default rst engine Q
I have an escort rst mfi turbo engine and my mate is interested in buying it for his fiesta xr2i but i dont know if it can be fitted???
Old Mar 11, 2006 | 12:10 PM
SafeChav's Avatar
SafeChav
It can be fitted but its a lot of arsing around it would be much easier for him to use a FRST engine, and he can retain his original wiring loom.
Old Apr 5, 2006 | 01:08 AM
fords4fun's Avatar
fords4fun
can he use the escort engine with efi and frst ofab ecu after making the right changes to his loom
Old Apr 5, 2006 | 08:35 AM
Oranoco's Avatar
Oranoco
Yes but the block will require drilling to accept a CPS (crank position sensor). I think (not 100% sure) that electronic coil pack from the XR2i can be reused so you will just need th eblanking bung for th ehead where the distributor would go
Old Apr 5, 2006 | 10:06 PM
SafeChav's Avatar
SafeChav
As Oranoco said, although there are other means of obtaining a CPS signal if you don't feel to clever with the drill. Im 99.9% sure the coil packs are the same but don't over look it. The cams fitted to FRST engines also produce a little more power than the cams fitted in the earlier MFI engines.
Don't forget you will also need to change the plug for the MAP sensor, and u will need to get a Marelli MAP sensor. I think thats all
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
