new wheels on the s1
Old Mar 10, 2006 | 10:08 PM
andysrs's Avatar
andysrs
Default new wheels on the s1
Started doing a little work on the car new 17,s i did like the dc 7 spokes but are very common now and having rear discs with 7.5 j rims means the rear cant be lowerd as the dc 7,s have a et35 offset so i couldnt lower the rear, the new wheels have an et42 ofset so they sit under the arch now but on the front anything over et38 requires spacers otherwise on tight corners the tyres will scrub the inner wings so now has 5mm spacers on the front to put it to et37,also started fitting the new pro alloy front mount cooler with twin fans not an easy job when your healthy let alone when you had a major op 4wks ago lol, will finish it over the weekend, ANDYSRS
Old Mar 10, 2006 | 10:09 PM
T28 RST's Avatar
T28 RST
Ok then
Looking stunning as usual Andy
Once you get the new springs on it will sit perfect
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
