piston,rods crank!!!
Old Mar 9, 2006 | 07:51 PM
shane's Avatar
shane
Default piston,rods crank!!!
i wana build a 2.1 i want some low comp pistons but does any1 recomend any?also does it really matter what comp ratio i pick from the start?
also what sort of power are the standard rods good for but im not too bothered if i have to fit farndon ones or sumats!
the big question is the crank would it be ok to just have the standar one lightened and balanced?cus i would say a steel one would cost a bomb!
also any advice about building a 2.1 would be much appreciated!
Old Mar 9, 2006 | 08:35 PM
Andy_R's Avatar
Andy_R
A couple of routes spring to mind in determining what components you will need.
1st. Plucking a realistic figure out the sky and having your engine built to reliably run that power.
2nd. Spec bottom end to run more power than you need, with a view to unleasing its potential at a later date.
Ultimatly it all down to budget and what you can afford to spend or want to spend on your build.
Old Mar 9, 2006 | 09:21 PM
JimmyBoy's Avatar
JimmyBoy
I think there should be some kind of sticky for this - "Zetec Build FAQ's" or summit, because the amount of times it crops up is unreal!
Old Mar 10, 2006 | 04:37 PM
shane's Avatar
shane
thanks andy r,i think route 1 will be best.i want about 280bhp any ideas what sortta spec id need?
Old Mar 10, 2006 | 05:37 PM
Andy_R's Avatar
Andy_R
Shane there are a few methods.
See the Search function at the top of your page, enter
zetec AND turbo AND rods AND pistons <<<<< copy & paste
into it and you will gain a wealth of knowledge
hope that helps
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
little bram
Sep 27, 2015 07:45 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
