Centre vent heater control pods - help please
I am currently searching for a decent pod that asn't been broken where it screws in and the black backing has not gone 'spotty' if you get me
Though i was onto a winner today as found a 20k miles escort Ghia in scrappy today - of course took some well needed parts, put pod in tonight so can see how it lights up
OK, it lights up perfecto, but it's so much dimmer than the ones I have seen before
looked at the part numbers on the back and they are different
I presume there is a pod with a white control unit and one with a black control unit
Anyone else found this out or are you not just as fussy as I am??
i didn't like the dimmer one, looked out of place if you get me??
Im not as fussy as you James
Come to think about it I dont think I have ever had mine light
I assume its not something as simple as bulb strength?
I do know what you mean about the pods breaking where they are screwed in though, I recon your on the right path with non RS's.
Not like anyone will have tapped into the wire that sits just behind to feed guages.
