running on 3 cyl..(help)
Old Mar 8, 2006 | 11:19 PM
chrisErst's Avatar
chrisErst
Default running on 3 cyl..(help)
after fitting new spark plugs, dizzy cap and HT leads my car was running fine but went out in it the other day it was only ruinning on three cylinders, after checking the plugs, i found that it was the fourth cylinder that wasent working, so i changed that plug for another new one and it went on three again uintl half way up the street when it burst in to life, but now no matter wot plugs are in it it only seems to be running on three.
if u can make sense of that then any help would be appreciated)
cheers chris
Old Mar 9, 2006 | 12:04 AM
NUTS RuS's Avatar
NUTS RuS
Is the dizzy cap ok ?
Old Mar 9, 2006 | 07:58 AM
chrisErst's Avatar
chrisErst
yeah should have said, it got replaced at the same time as the plugs n leads.
cheers
Old Mar 9, 2006 | 05:27 PM
NUTS RuS's Avatar
NUTS RuS
What colour is the plug from the faulty cylinder after a run ?
Im still thinking of a duff plug / lead or possibly a fuel delivery problem at the minute
Old Mar 9, 2006 | 06:58 PM
sexr3i's Avatar
sexr3i
isn't it
was it fine before you serviced it? I'd say lead. try the old one.
Old Mar 9, 2006 | 07:28 PM
chrisErst's Avatar
chrisErst
car was fine before service, it jsut hadnt been done in a while,
it ran fine for a couple of weeks after the service, then just started doin this the other day.
cheers
Old Mar 9, 2006 | 07:42 PM
does it only do it when ya start her up the 1st time during the day?
does it do it after shes firing on all 4, if you turn her off then restart?
Old Mar 15, 2006 | 11:41 AM
chrisErst's Avatar
chrisErst
finalluy got the chance to look at it,
the plug from the the faulty cylinder is black, in colour, soot deposits i think
diamonds - no, it does it every time you start her up, and it runs on three again if its been runnin on 4 ten u turn her off, but now the car wont start without a jump
sorry for very late reply, thanks for any help
cheers
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
