Anyone on here got a MTX in a mk3/4 Escort?
Makes it even less stress if you have the Zetec bottom end.
You need a S1 antiroll bar. Then our fabiricated mounts/brackets for the box bolt on.
The box bolts straight on to the block using decent clutch & plate etc...
The shafts are 909 parts using a two or THREE piece shaft setup.
Outer ends are 909 parts for a cossie and a RS2000 modded to fit a mk3/4 hub assembly
The only modd needed to do to the chassis is:-
The N/S chassis inner. This needs a section about 3in long, cut and then welded back together allowing a little more room for the box to clear the side.
Price depends on what parts you need i.e BOX, S1 Roll BAR, MOUNTS/BRACKETS, SHAFTS, CUPS, HUBS, BEARINGS, WELDING
Regards
Jano
Regards
Jano
got a 16i front anti roll bar.
can do the chassis mod.
So its bassically to supply the other bits
so a price would be great mate
i can source a box also, but it depends how cheap you can supply one.
Oh and craig, im never one to shy away from a mission
i can supply boxes from Ł150 - Ł400 depending on the day of the week and the weather i have to take one out in
Its not that of a mission
the final outcome is well worth while.
Originally Posted by B19-TRB
ryan i thought we went through this the other day for the money difference buy a fookin bocx of bernie! @ least ya got a good diff & a warentee & it botls straight in!
The gear change linkage is really easy.
Its the mounts, drive shafts and clutch that are the problem.
I decided for the hasstle and cost it was better to buy a Bernie box
P.S. if anyone needs a nice focus MTX75 gear change i have a nice lift reverse one
Dr. Ickxs
Sep 15, 2015 10:15 PM
