stainless steel bolts-where from??
Old Mar 7, 2006 | 07:34 PM
Mr C's Avatar
Mr C
Default stainless steel bolts-where from??
Where about do you get your new bolts from, I have tried endless times it the past to get the correct bolts ordered direct from Ford and usually get the wrong items sent So Im looking for a supplier for nice new Stainless steel bolts for my rebuild, a selection of M6 through to M10s for things like Anto roll bars and rear beam mounts, seat mounts etc. Also new Screws and clips for the engine bay area too.
Who do you use??
Old Mar 7, 2006 | 09:27 PM
2litresi's Avatar
2litresi
there is a place down loughborough road i will get the number tomor for u
Old Apr 13, 2006 | 11:41 AM
MichaelG's Avatar
MichaelG
Look up your local Fasteners outlet in the Yellow Pages, i got every nut bolt and washer i needed in Stainless from my local Fasteners supplier.
MEGA cheap compared to fords prices too.....and they wont rust !!
Old Apr 13, 2006 | 04:01 PM
Brookesy's Avatar
Brookesy
Try Namrick you can choose all the sizes you need although for rear beam mounts and other suspension bits you shouldnt use stainless steel bolts get some zinc coated bolts.
http://www.namrick.co.uk/
Old Apr 13, 2006 | 04:08 PM
lamb chops's Avatar
lamb chops
Why is that, just interested as was going to kit mine out over the winter?
Old Apr 13, 2006 | 04:26 PM
Brookesy's Avatar
Brookesy
Too brittle, dont have the same tensile strength as the bolts already on the car.
Ideally you need bolts with the numbers 8.8 on the head
Old Apr 13, 2006 | 07:27 PM
Mr C's Avatar
Mr C
A good range and a catalogue on the way
12.9TS bolts available for chassis and brakes
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
martynhomer01
Oct 1, 2015 12:05 AM
stevecfrst1
Sep 30, 2015 05:18 AM
