ever heard of a -32 actuator?
Old Jul 27, 2004 | 01:19 PM
weegaz22's Avatar
weegaz22
Default ever heard of a -32 actuator?
got my actuator through in the post this morning and the numbers stamped on it are 9.074 which i assume is something to do with the spring
and 430099-32 just wondering if anyone has ever heard of this before
Old Jul 27, 2004 | 01:41 PM
Jim Galbally's Avatar
Jim Galbally
what did you actually order?
Old Jul 27, 2004 | 09:47 PM
weegaz22's Avatar
weegaz22
it was advertised as a -32 but thought it may have been a misprint as i havent ever seen -32's for a cossie
Old Jul 27, 2004 | 10:39 PM
Jim Galbally
iirc (and i may well be wrong) i think i heard sum1 (possibly stu) once say that a -32 is a standard actuator...
but please check that info with sum1 else as i'm probably wrong
Old Jul 27, 2004 | 11:24 PM
SPADGE's Avatar
SPADGE
That is a standard one i believe!
Old Jul 28, 2004 | 12:08 AM
weegaz22's Avatar
weegaz22
its going on my rs turbo so that will do as i only want 15psi of boost, cheers
Old Jul 28, 2004 | 12:27 AM
weegaz22's Avatar
weegaz22
just out of interest does anyone know what the numbers mean?? for instance a stock s2 actuator is a -22 so going higher to -31 or-34 gives better boost holding ability , so how come a -32 is a standard cossie one? and a -31 is a better?
Old Jul 29, 2004 | 08:16 PM
weegaz22's Avatar
weegaz22
Old Jul 29, 2004 | 08:18 PM
cossie1's Avatar
cossie1
always thought a -30 was a std cossie item ?
Old Jul 29, 2004 | 08:19 PM
weegaz22's Avatar
weegaz22
not according to spadge and galbally
Stu.H's Avatar
Stu.H
not sure u will get 15psi out of a standard???
Old Jul 29, 2004 | 08:21 PM
EIL132's Avatar
EIL132
-32 is Fiesta RST actuator.
Old Jul 29, 2004 | 08:22 PM
weegaz22's Avatar
weegaz22
is it a standard one though? and what does the cossie run as standard boost, its for an s2 rs turbo
can anyone explain the -31,-32,- 22?? i always thought that the higher you went the stronger the spring inside which would hold more boost
Old Jul 29, 2004 | 08:23 PM
weegaz22's Avatar
weegaz22
but it has T3 stamped on it
Old Jul 29, 2004 | 08:24 PM
EIL132's Avatar
EIL132
Does it have a kink in the arm?
Old Jul 29, 2004 | 08:26 PM
weegaz22's Avatar
weegaz22
nope, but i used the arm of my car as it didnt come with one, but the actual rod itself isnt bent
Old Jul 29, 2004 | 08:27 PM
weegaz22's Avatar
weegaz22
i bought it off a guy who was selling a load of cossie parts, said it was for a 2wd t3 turbo
Old Jul 29, 2004 | 09:10 PM
weegaz22's Avatar
weegaz22
anyone know what it is for/off of?? starting to get confused
Old Jul 29, 2004 | 09:12 PM
SPADGE's Avatar
SPADGE
Rest assured it is not the spec of a -31 so bin it and buy a proper one
Old Jul 29, 2004 | 09:13 PM
EIL132's Avatar
EIL132
Class C Modified Turbo.
Only the standard production MG Metro Turbo turbocharger unit or STR 985 are permitted, together with actuatorcapsule STR 1081 (stamped 430099-32). The actuator setting is 5.0psi for 0.015” (0.38mm) of actuator rod movement.
Old Jul 29, 2004 | 09:14 PM
weegaz22's Avatar
weegaz22
lol that still doesnt help me
Old Jul 29, 2004 | 09:16 PM
SPADGE's Avatar
SPADGE
I reckon that - before 32 is a line in between the part number and not a dash as such!
nomad's Avatar
nomad
the dash bit is only applicable to garrett, its one of their part numbers, dash 31 dash 32 etc has no significance in determining spring pressures etc so a dash 27 could be stronger than a dash 34, i think stu's you best man to answer a garrett question. cheers nomad
Old Jul 29, 2004 | 09:22 PM
weegaz22's Avatar
weegaz22
cheers
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
Marv888
Sep 26, 2015 03:44 PM
