90 spec
right. i'm lookin at purchasin my first rs in the next few weeks, i've had a few mk6 escorts but i really fancy an erst. this question has probably been asked a million time on here but i was wondering what the differences between an older rst and a 90 spec apart from the bumpers?
cheers for the help guys an gals
Front bumper, modified to allow more air to the radiator to aid cooling. It no longer has a rubber strip below it.
Boot spoiler, curves down at either side
ECU, was changed to the hearts and diamonds type. This can run 10.2 PSI of boost.
Interior, the seats and door cards were given new patterns, called Zolda. It is grey with blue and red flecks.
Roof lining and sun visors are a different colour, as are the speaker panels, kick panels, and rear quarter panels.
Intermittent wiper speed control was added to the right hand dash column controller. Supplementary manual produced by Fords to cover this modification.
Second courtesy light was added in the rear of the car roof lining.
Centre console, a second part was added to extend the length of the console, handbrake handle had a different cover.
Screen wash reservoir wash changed slightly, it now has a thicker neck and incorporates a plastic gauze to stop any debris from entering the screen wash reservoir.
Brake fluid reservoir updated.
Rocker cover changed, holes for the charge carrier bolts moves out a few inches.
Charge carrier, bolt holes to connect to the rocker cover moved over a couple of inches.
Dash clocks, the fuel and temperature gauges are reversed. Fuel on left, water temperature on the right now.
Oil dipstick pipe, end is now plastic rather than metal
rear spoiler is better looking, front bumper you know, interior trim is light grey with chequed pattern with red and blue dashes,as opposed to the earlier dark grey with red dashes and most 90 specs come with fuel computer.
no real difference really mate apart from the already mentioned bumpers front and back (90 spec bumper got bigger vents to aid cooling),erm rear spoiler is different(bends over at each side rather than folding around on the earlier spec.also the interior was updated to red grey and blue specks,i think it was called zolda whereas the older one was just red and grey speck.temp gauge on some of the later models was on the far right i.e petrol then temp but again earlier ones was other way round,the only other thing i can think of is the rear lights on a 90 spec came standard with smoked lenses,i think thats it of the top of my head,might b more but thats all i can think of at the mo.
hope this helps
rick e
hope this helps
rick e
Everyone seems to think 90 spec S2s came with smoked lights but they are no different form the earlier lights
Mine is G, 90 spec and has the later temp/fuel gauge, heated screen, intermittant wipers, extended console, rear courtesy light, different & thicker h/brake cover to my old 80 spec but no fuel comp
ive had 89 xr3i and s2 that both had the 90 spec interior but older style bumper and spoiler. had this argument with my mate before who swears blind that you wouldnt have the newer trim without the newer bumper/spoiler. but i know that you can
dave y
yeah mine IS the other way round 88spec bumpers and spoiler but 90 spec trim,like i say thats how it left the showroom,i suppose its alot less aggro updating the trim rather than start unbolting bumpers and spoilers
[/b]
[/b]
Originally Posted by dave_y
s1_turbo
that in my eyes is the perfect combination. especially on red cars.
you usually get it the other way around though.
i had a black g-reg s2 that had earlier interior but bumper and spoiler had been changed to 90 spec. loved that car
The red ones sold now, first RS bought when i was 18. Crippled me on insurance
had it for a few months and had the grey one ever since. Cosworth in the garage was my dads. Focus RS comin soon though
s1 turbo
just wondering if that roof arial was an aftermarket item or it came as standard as i have one on mine exactly the same place too and mine is an f plate too,but i thought the arial was built into rear screen,but seeing urs has got me thinkin
[/b]
cheers for the info fellas. gonna have to decide wether to shell out a bit extra for a 90 spec, think i might. i'm gettin bored fast of my latest car, i strayed over to the dark side and bought a vauxhall! gonna be back with ford soon enough though!!
Thats got to be the most detailed answer you could possibly get you know ya stuff mate well done
