stainless steel inlet on a cosworth the one sib is selling
is it a problem to use a stainless steel inlet manifold on a cosworth like the on sib is selling on here the Swedish style ones would there be a problem with heat and flow and location of this inlet could some one explain I though alloy was better at heat transfer
Originally Posted by K.Goa
*danger to manifoild* comes to mind
only one I`ve ever heard of slitting a plenumchamber is Stian Hafsengen with his old carbon manifoild.
Alloy may be better at heat transfer, but as the item is an inlet plenum not an Intercooler, and is on the cold side of the engine I really don't think this will be any form of issue at all.
The reason I've made this in stainless is on the grounds of strength - a friend has a 540bhp Escort Cossie, his ally plenum split twice. He now runs this same plenum with no problems.
As mentioned by EscosNige, he was supplied his plenum by Reyland, who in turn has bought it from us. I think that is fair endorsement
Link to my ad on here:
https://passionford.com/forum/viewtopic.php?t=180132
And to my ad on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE%3AIT&rd=1
Currently on Ł165 which is bargain IMHO.
Any questions anyone has please fire away and I'll try and help out!
Simon
Simon
Thanx Chip, kind of you to post. Chip bought the prototype one from me which is now on B9KOS's car.
The plenum being sold comes with a bracket welded on the underside to join up with the top of the engine mount in a similar way to the original inlet manifold.
As Chip has pointed out, you don't want the weight of the plenum, fuel rail, loom and injectors etc ripping the head bolts out!
Simon
Simon
R4N S S
Not up for retail sale at the mo as I'm not registered as a trader yet. Also getting website made and a whole lot of other blingy bits made as we speak. Looking to launch tail end of April hopefully.
Zoo one is Ł350 + iirc in ally
A1 one is Ł350
Some Swedish ones are that and more.
The current one on ebay is Ł165. No reserve either so what it goes for it goes for.
Simon
A1 one is Ł350
Simon
The only thing I would say is that an inlet plenum needs to be designed on a flow bench to give equal flow to all cylinders. If this has not been done and more air gets to one particular one, then unless you have an ECU that can trim fuel for individual cylinders, it will melt
. The Swedish ones that I sell have been tested on an engine dyno and flow bench to get the optimum spread of air between the four cylinders
Regarding the alloy plenums that have failed, these have all been inferior copies of the Swedish ones. There has never been a Swedish plenum supplied by me that has failed in any way, shape or form
. The Swedish ones that I sell have been tested on an engine dyno and flow bench to get the optimum spread of air between the four cylinders Regarding the alloy plenums that have failed, these have all been inferior copies of the Swedish ones. There has never been a Swedish plenum supplied by me that has failed in any way, shape or form
matman
Sep 9, 2015 05:45 PM
Aug 14, 2015 07:29 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
