Bluesprint......
Just bought a 2wd Saph with a Bluesprint built engine in that's done 14k,have seen a couple of peep's on here with Bluesprint built engines(DOO,SPADGE)just wondered what you lot know of this company??
Its got,200 long studded block,Mahle pistons,lightened balanced bottom end,WRC gasket,BD10's,big valve ported head,matching ported manifolds,up-rated oil pump.
DOO doesnt really know much about the enigne & i think he spoke to the guvna down there & was as helpful as he could b!
the engine seems fine sounds good & has just had it stage 3'd (320hp) so she goes a wee bit better now!
t34 & big cooler next i recon!
Mine had a rebuild before i bought it by BLUESPRINT now done 5000 miles since rebuild no knocks or rattles. just the turbo worked it`s self loose but just neede tighting up
Just had it set up the weekend with no probs
Don`t really know a lot about them but what i have been told there meant to be the bolloxs
Cheers peeps
Got a rolling road print out with the car from when it was running a hybrid T3,says 334 bhp at 7150 rpm!!
The print out is from Power Engineering,did I read something on here that there figures are a bit on the high side???
Apparently it's greens are running at full cycle
suprised the peak power is so high up on the rev range
would think the turbo would run out of puff?
Many people on here rate them highly, Steve3drals (itsmeagain) is one of them I beleive, however, as with any company you do get people who think they are shit...
Yeah,I thought it was at high revs!
Print out reads:max power 334 bhp at 7150rpm,291 lbs/ft peak torque.
Running a T34 now,lad I had it off said power run was with hybrid T3,wonder if hes tellin porkies????
Joe Stevens knows his stuff and in the racing game is held in high regards ! Ive always found him very helpful and eager to chat about these cars and the other stuff he gets involved with , anything upto and including F1 engines. i also have raced against cars powered by his engines, Phil Libby for example has a 600hp Sapphire , he was a bit quicker than me round Snetterton !! ( Not Much tho ! )
Libbys Saff is AWESOME
And yea, Joe does a lot of F1 Turbo engines, so i think he can handle a YB no prob, lol.
The amount of F1 turbo stuff he has is unbelivable, shedloads of engines, internals, turbos, manifolds, wastegates, everything.
and it deffo came from a black 3dr with a white cage he took to a 1000bits, i guess so.
