air injector driver?
Old Mar 5, 2006 | 05:41 PM
fordsportjay's Avatar
fordsportjay
Default air injector driver?
hello,ive just got my air injectors off daz c and they look a quality job.now i bought a l8 ecu which is supposedly set up to run t4,greys and air injector.where would the driver be in the ecu-would it be one of the smaller chips on the small board?or should i be looking elsewhere.
never had this set up before and just want to make sure its right before i fit it all/run the car.
Old Mar 5, 2006 | 05:57 PM
DazC's Avatar
DazC
Jay, the ECU should either have a Pectel board in it or it will need an external driver soldered into the loom (which MSD can supply. Its only a 4 wire job).
Old Mar 5, 2006 | 06:01 PM
fordsportjay
its got the board in it,would it be a plug in chip or something more obvious?
i just remember looking into a p8 ecu i had that used to run the engine now in my rs500,which was modded for antilag and some other bits,and that had extra bits soldered into the main board.i just want to check really,i trust the bloke who sold it to me as he didnt know i wanted to run air injectors,just curious i suppose more than anything
Old Mar 5, 2006 | 06:09 PM
DazC's Avatar
DazC
Not too sure which part on the board it is to be honest. I do know that the signal has to be inverted.
Old Mar 5, 2006 | 06:12 PM
Sticky.'s Avatar
Sticky.
Take a pic of the ECU with the lid off & im sure someone will reconise the software & driver.
Old Mar 5, 2006 | 07:09 PM
Tony Ryan's Avatar
Tony Ryan
You really want to know if the Air-Air Injectors youve just bought are EXCACTLY the same as the ones your board is mapped for as well as a different size injector will bleed different amounts of air , ok if it bleeds more but an expensive mess otherwise
Old Mar 5, 2006 | 07:47 PM
DazC's Avatar
DazC
Good point Tony!
Old Mar 5, 2006 | 08:01 PM
fordsportjay
yes ill look into it a bit more
Old Mar 5, 2006 | 08:06 PM
fordsportjay
Item number: 4610373717
there is some pics and info on this on ebay.doesnt mention air-air but he emailed me and told me before i bought it
Old Mar 5, 2006 | 08:13 PM
fordsportjay
Old Mar 5, 2006 | 08:14 PM
fordsportjay
Old Mar 5, 2006 | 08:25 PM
fordsportjay
bigger pic
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
mondeomark
Sep 28, 2015 06:28 AM
Russ Payne
Sep 25, 2015 08:29 PM
