Fao Electrical bods!
I've got a Sony Bullet cam to fit to the bike to aid the prosecution
It comes with a little 8 x AA battery pack to run it but I'd rather run it from the bikes battery.
I assume I wont be able to run it straight from the battery due to the varience in voltage due to charging/load?
The camera needs a 12v DC input with 120mA power consumption.
Is it a regulator I need to keep the voltage constant? Anyone know a good place to get one???
Thanks in advance
Thanks in advance
It should be ok Lee,you already have a regulator on the bike to stop any voltage spikes and the camera will probably work with anything from about 9-15 volts pretty safely...
Cheers mate, you think it'll be ok?
It says any more than 10% deviance from 12v will cause 'abnormal operation' so that's 10.8v-13.2v and I haven't checked the battery but I'd expect to see circa 13.8v when it's running.
I guess I'll have to suck it and see
I`ve found it tends to be more like 15-20% mate with the ones i`ve used so you might be ok.....
