fiesta turbo management
would it b worth maybe running fiesta management on my escort turbo estate,what would be the best ecu 2 get,whats the difference,would an ofab ecu be ok 2 use
Im looking to do the same thing on mine, just for the chatter!
Ive been looking for someone to do the swap from mfi to efi on mine, but no-one is really that intrested
(Apart from Jano!)
Do you fancy swapping mine? If i supply all the bits needed?
I would try it myself, but when the loom and injectors map sensor and stuff gets involved my brain goes to mush!
Let me know wot you think jonesy
(Apart from Jano!)
Originally Posted by rightstuff
look on rsbible.co.uk
so if i get a fiesta rst ecu i could plug it in 2 the xr3i loom as long as its the right ecu i should b ok yeh
[quote="jonesymk2"]
Only if your currently running with an XR3i efi loom. If not then you will need to cut/splice the looms about.
[quote="S1"]
ive got a whole xr3i which i can take everything out of so i will just swap the whole loom over into my estate,im changing the dash board anyway so that will help me out a bit should hav the looms swapped in a day really shouldnt i
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
