inlet manifold
Old Mar 5, 2006 | 12:58 PM
s2 ben's Avatar
s2 ben
Default inlet manifold
my s2 has got the wrong inlet manifold on where the knock senser plugs in its just got a pipe going to master cylinder been told it is ok 2 drive it like this at the moment it has got a s1 ecu in it but i am putting a s2 1 in it 2morrow. so do i need 2 get a new inlet manifold aswell
Old Mar 5, 2006 | 01:24 PM
James Raby's Avatar
James Raby
Um, you just have an early inlet, not all RST's had a knock sensor, that pipe is meant to be there - do not unplug or unscrew it
Do you have a knock sensor plug wired in??
btw, it actually goes to the servo - NOT master cylinder
Old Mar 5, 2006 | 01:51 PM
s2 ben's Avatar
s2 ben
oh right it as all the wiring for a knock senser tho my old s2 was a 88 that had knock senser if i swap the ecus will it mess up the timing
Old Mar 5, 2006 | 02:13 PM
James Raby's Avatar
James Raby
The pipe from inlet (black one) goes to servo - don't touch it
as far as the other, I really don't know mate
Old Mar 5, 2006 | 02:20 PM
s2 ben's Avatar
s2 ben
ok thanks 4 ur help mate
Old Mar 7, 2006 | 06:28 PM
HORNETS7's Avatar
HORNETS7
the knock sensor goes below the pipe for the servo !!
some early rst's didn't have knock sensors as said above !
does yours have a green multi plug near the inlet manifold then?
Old Mar 7, 2006 | 06:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its all relevant to wether or not the ecu your about to fit requires the sensors or not?
Old Mar 8, 2006 | 04:12 PM
s2 ben's Avatar
s2 ben
yes the ecu i am gona fit is hearts and diamonds so i do need to change inlet manifold 4 1 with a knock sensor or it will mess up the timing thats if i have been told right just cant figure out why it has got the wrong parts on in the first place
Old Mar 8, 2006 | 04:14 PM
s2 ben's Avatar
s2 ben
HORNETS7
sorry mate yes the green plug is all there
Old Mar 8, 2006 | 04:50 PM
robbob's Avatar
robbob
IVE JUST PUT A NEW ZVH IN MY S2 AND INLET MANIFOLD HASNT GOT A KNOCK SENSOR IN BUT MY OLD ENGINE HAD ONE WILL I BE OK OR WILL IT NOT RUN RIGHT
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
