Big brakes with standard callipers
Old Mar 4, 2006 | 05:34 PM
cosworthcapri's Avatar
cosworthcapri
Default Big brakes with standard callipers
Anyone know where i can get 330mm discs and brackets to allow me to use standard callipers with them on a 2wd sapphire?
Old Mar 4, 2006 | 05:38 PM
slowpoke's Avatar
slowpoke
shite spec (hi spec) probably could sort you out
ive got there big disc kit on my saph but its only 28 x 310mm bells and rotors but as gracie said with a good set of pads it works very well
martin hadland or brom when he is better could also probably help you
matt
Old Mar 4, 2006 | 05:44 PM
cosworthcapri
Thanks, il give them a try,i dont mind using 310mm,they wil do.
Old Mar 4, 2006 | 06:14 PM
Muzz's Avatar
Muzz
Whats the biggest disc you can use with 4wd calipers?
Old Mar 4, 2006 | 07:08 PM
Micky's Avatar
Micky
You'd be better off getting Reyland (Martin H ) to sort you out,as Lo-Spec are a cowboy outfit !!! Regards Micky
Old Mar 4, 2006 | 07:26 PM
Sticky.'s Avatar
Sticky.
I had 325mm on standard callipers before i upgraded.
Old Mar 4, 2006 | 07:34 PM
stevedohc16v's Avatar
stevedohc16v
cough cough , Godspeed do or did? a 325mm kit for use with standard calipers.
Steve
Old Mar 4, 2006 | 09:06 PM
boost mad's Avatar
boost mad
and when i got hold of them the disc would not physicly fit in the calipers
Old Mar 4, 2006 | 09:10 PM
SPADGE's Avatar
SPADGE
Paul why does that bell have O/S written on it and you have it on the N/S
Old Mar 4, 2006 | 09:17 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Well spotted
Steve.
Old Mar 4, 2006 | 09:19 PM
dave cos4x4's Avatar
dave cos4x4
you are just testing your eyes out now Jules.
Old Mar 4, 2006 | 09:38 PM
SPADGE's Avatar
SPADGE
Lol just a tad bored mate
Old Mar 5, 2006 | 12:49 AM
alfacossie's Avatar
alfacossie
lol pmsl thats ford engineering at its best lol
Old Mar 5, 2006 | 11:20 AM
Muzz's Avatar
Muzz
So would i be able to use them on my MK6 Escort? Currently running a 4x4 Cossie setup on the front, and the calipers have had to be spaced out 6mm from the hub.
Old Mar 5, 2006 | 06:06 PM
Sticky.'s Avatar
Sticky.
Well you must have done something wrong, cause you can see they were on my car & they came straight off Lukes car & fitted mine perfect.
Old Mar 5, 2006 | 09:56 PM
wildheart's Avatar
wildheart
You have to split the calipers and fit a spacer
s1cab
Jul 26, 2018 06:11 PM
YODI
Aug 30, 2015 01:12 PM
cossynut2
Aug 19, 2015 11:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
