10mm spacers for plenums....
Old Mar 3, 2006 | 06:16 PM
Default 10mm spacers for plenums....
How the fuck you meant to put the fuel rail on... Obviously you cant go in on the back....and on the front neither
HELP!!!!
Old Mar 3, 2006 | 06:22 PM
Billabong's Avatar
Billabong
You need some brackets, which aren't required for the 14mm one. Try Genesis Engineering?
Old Mar 3, 2006 | 06:28 PM
FFS i need to get this running by Sunday Any pictures of these brackets?
Why dont you need them on the 14mm spacer?
Old Mar 3, 2006 | 06:30 PM
Karl's Avatar
Karl
Norris Motorsport
Phil, the fuel rail bolts on the front of the lugs, but you will need to trim the lug thickness down by removing material from the front face of the lug until the rail is in the correct alignment.
Old Mar 3, 2006 | 06:32 PM
Cheers Karl...i never thought of that
Problem solved
Old Mar 3, 2006 | 06:36 PM
Billabong's Avatar
Billabong
You have a remedy
Phil, I don't use one, was going by something Genesis said on an old post. The thicker one will move the rail further away hence no clearance issue I guess.
Old Mar 3, 2006 | 06:38 PM
Yeah...so basically i have to trim 4mm off
Old Mar 3, 2006 | 06:39 PM
SPADGE's Avatar
SPADGE
When i used a 20mm spacer i put the rail the other side of the lugs using nuts and bolts. I'm guessing thats of no use to you though as your kind of in between
Old Mar 3, 2006 | 06:41 PM
le-claw's Avatar
le-claw
Can't believe he needed to ask
Old Mar 3, 2006 | 06:54 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
That's why we're all here though fella to help each other out when needed..................
Old Mar 3, 2006 | 06:55 PM
leecavturbo's Avatar
leecavturbo
not much in the way of creativity eh
Old Mar 3, 2006 | 07:26 PM
Stu @ M Developments's Avatar
PassionFords Creator
I explained that to you last week Phil...
Old Mar 3, 2006 | 07:35 PM
Billabong's Avatar
Billabong
Old Mar 3, 2006 | 08:50 PM
Stu you said 14mm was perfect...not 10mm...you didnt explain what was needed to do
Of course now all seems obvious,SILLY me
DIY is hard when you aint a mechanical
Old Mar 3, 2006 | 08:56 PM
I did...
I said "Get a 14mm one instead"
Old Mar 3, 2006 | 09:16 PM
le-claw's Avatar
le-claw
No CSE maths for you either then....
Or a shatterproof 30cm ruler
Can't believe karl is helping you after all the shit you cause, top stuff forgive and forget
Old Mar 3, 2006 | 09:58 PM
Dingy....like Karl himself said...he speaks for HIMSELF ONLY...
Top bloke...i admit giving him shit a LONG time ago..but then i didnt know him...its a pity you dont get to know Ahmed after the shit you give him!
Your worse than anyone mate!
Old Mar 4, 2006 | 07:23 AM
Cossie Helen's Avatar
Cossie Helen
Old Mar 4, 2006 | 08:38 AM
Basky's Avatar
Basky
easy option,fab a new plenium
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
