The car has died--Need help
Old Jul 26, 2004 | 08:43 PM
TIFF's Avatar
TIFF
Chasing Radders
Default The car has died--Need help
Not the engine though
Just driving along about 20 minutes ago and i flashed the headlights. The car just died!!
All that came on the dash was the red battery light and then it stoped. There is no dashboard lights and the car turns over but wont fire.
I have checked all the blade fuses under the bonnet and they are fine, could it be the ignition rely, if so where is it???
Also when i took the ECU cover off the Earth strap that goes on the screw of the ECU wasnt connected, would this of coursed it???
Help need please
Old Jul 26, 2004 | 08:45 PM
RSrussell's Avatar
RSrussell
Have you checked the tyres?
No dashboard lights wouldn't point to a relay would it more alternator/battery i would have thought?
Rene's Avatar
Rene
i reckon the alternator might be fooked and empty ?
Old Jul 26, 2004 | 08:46 PM
TIFF's Avatar
TIFF
Chasing Radders
The battery is fine as all the alarm and stuff works fine
Physio's Avatar
Physio
Sounds like it could be the alternator mate.
Old Jul 26, 2004 | 08:47 PM
Physio's Avatar
Physio
Old Jul 26, 2004 | 08:48 PM
Rene's Avatar
Rene
there are also some fuses under the dash ... do you hear the fuelpump when switching on ign ?
Old Jul 26, 2004 | 08:49 PM
TIFF's Avatar
TIFF
Chasing Radders
No, dont hear the pump prime up either
Old Jul 26, 2004 | 08:55 PM
EIL132's Avatar
EIL132
Immobiliser?
st3v3's Avatar
st3v3
tiff,check from the battery,there should be a small wire that goes to the loom,on + side,try it,common fault on older fords,but from what i remember i think this will kill everything
hope this helps
Physio's Avatar
Physio
Have you checked the voltage on the battery Tiff? If so, what is it?
Old Jul 26, 2004 | 08:56 PM
Physio's Avatar
Physio
st3v3's Avatar
st3v3
ooeerrrr ive just done my 1001 post
Old Jul 26, 2004 | 08:59 PM
TIFF's Avatar
TIFF
Chasing Radders
Not checked the voltage on the battery but it is about 3 months old
Steve
Hello mate I will check
Old Jul 26, 2004 | 09:02 PM
Physio's Avatar
Physio
If the alternators packed up the battery probably hasnt got enough power to run the ecu, you see?
Physio's Avatar
Physio
TIFF's Avatar
TIFF
Chasing Radders
Is the ignition relay in the drives side footwell?
Old Jul 26, 2004 | 09:04 PM
EscortWRC's Avatar
EscortWRC
Doesn't matter if your battery is brand new if it is not being charged
Old Jul 26, 2004 | 09:05 PM
TIFF's Avatar
TIFF
Chasing Radders
But it was running fine until i flashed the headlights
Old Jul 26, 2004 | 09:06 PM
Physio's Avatar
Physio
& that was the final straw for the alternator!!
Old Jul 26, 2004 | 09:07 PM
Physio's Avatar
Physio
RSrussell's Avatar
RSrussell
just a coincidence tiff, i've pick my nose and farted once
AJ, stop spamming
Old Jul 26, 2004 | 09:08 PM
TIFF's Avatar
TIFF
Chasing Radders
OK guys, i will check it
Old Jul 26, 2004 | 09:10 PM
JAP CRAP's Avatar
JAP CRAP
deleted my post
wtf is that all about.
Old Jul 26, 2004 | 09:14 PM
Physio's Avatar
Physio
Originally Posted by RSrussell
AJ, stop spamming
Hold on a minute, my name is'nt rhys racer 12 (or whatever he's name is)
Old Jul 26, 2004 | 09:15 PM
Physio's Avatar
Physio
AJ, stop spamming
Old Jul 26, 2004 | 09:16 PM
McPikie's Avatar
McPikie
Tiff, you wanna check the trip wire from the alt to battery, runs along near the rad. Mine went on my ERST, confised the fuck outta me for days mate.
Old Jul 26, 2004 | 09:18 PM
cossie1's Avatar
cossie1
I would check the main and fuel relay's behind the glovebox.
there s also some fuses down there too
Old Jul 26, 2004 | 09:19 PM
Physio's Avatar
Physio
Why do my posts keep getting doubled?
TIFF's Avatar
TIFF
Chasing Radders
Where abouts behind the glove box???
How do i know if a relay is fooked?
Old Jul 26, 2004 | 09:20 PM
Physio's Avatar
Physio
Old Jul 26, 2004 | 09:23 PM
cossie1's Avatar
cossie1
if it's the same as a saff, litterally put ya hand up behind the glove box and you should feel a load of relays, pull them down and you will find 2 yellow ones, 1 is the main realy and the other 1 (with fuse inline with ti) is the fuel pump relay.
they are both the same so you could try swapping them round and see if anything is different.
Old Jul 26, 2004 | 09:26 PM
AlexF's Avatar
AlexF
It could be your alternator but then the car would be compleely flat and not turn over or nowt...
sounds like a ECU prob, either a feed to it or a sensor down.
you need a relay tester... or get a new one.
Old Jul 26, 2004 | 09:47 PM
TIFF's Avatar
TIFF
Chasing Radders
HHmmmmmmmmmm
Just put a Level 6 into it
Old Jul 26, 2004 | 09:59 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
didnt you say that when you fitted some new head lamps ,you had problems getting them to work?that might be causing the problems you have now.check the earth points on the front chassis rails one on each side.also check the loom multi plug under the bonnet for good connection,common fault
Old Jul 26, 2004 | 10:02 PM
Jim Galbally's Avatar
Jim Galbally
no earth points on chasis rails on mk1 sierra mate
Old Jul 26, 2004 | 10:10 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
tiff my old saffy did this and it was the fuse links on the battery had fused lol and cut me the fook out in the middle of a juntion 2 new wires through suitable fuses cured that problem hth
Old Jul 26, 2004 | 10:14 PM
TIFF's Avatar
TIFF
Chasing Radders
Gus
Which wires do you mean??
Old Jul 26, 2004 | 10:15 PM
Rs Gus's Avatar
Rs Gus
the 2 on the battery that go to thicker wires just inside the sleaving i think they are red and blue and a red 1 see i can be nice hth mate
Old Jul 26, 2004 | 10:19 PM
stevo's Avatar
stevo
pmsl @ the double post
