Oil cooler Help
Old Mar 3, 2006 | 05:19 PM
rstoughy's Avatar
rstoughy
Default Oil cooler Help
Fitted up my sandwich plate ect for my cooler and the oilstat arrived today
Dose anyone know which hose is the feed to the cooler and which is the return?
I have spun the engine over and it looks to be the rear hose which is the feed as it fills with oil but the front hose also fills up but at a slower rate
Got to get this right as its going to be a nightmare to get to once the head is back on the car.
Heres a pic of the plate and hoses.
Any help apreciated.
Paul.
Old Mar 3, 2006 | 05:27 PM
Micky's Avatar
Micky
Now that's a bloody good question!! IF you did'nt have the stat it won't make any difference,but you do and I'm of no help to you at all. Time for a real expert to reply. Regards Micky
Old Mar 3, 2006 | 06:44 PM
rstoughy's Avatar
rstoughy
I know
Brasso's Avatar
Brasso
It doesnt matter does it?
I just connected mine up (thermoblock). I didnt think it needed to be one way or the other.
Old Mar 3, 2006 | 06:47 PM
The DIVA's Avatar
The DIVA
Paul....................The sandwich plate already has a stat built into it doesn`t it.?
Old Mar 3, 2006 | 07:02 PM
rstoughy's Avatar
rstoughy
noooooooooooo dont be telling me that Rob
Dose it ???????????
Old Mar 3, 2006 | 07:07 PM
Brasso's Avatar
Brasso
You can get the sandwich plates with or withou a stat. Ł15 - Ł20 without and Ł30+ with.
As you look at the plate youd see a screw in sensor with a visable spring inside the plate.
Old Mar 3, 2006 | 07:16 PM
Brasso's Avatar
Brasso
This is a normal one.
This is a thermoblock. You can see the stat in the corner.
Old Mar 3, 2006 | 07:38 PM
The DIVA's Avatar
The DIVA
Just checked mate,yours is deffo a thermoblock with a built in stat..
Old Mar 3, 2006 | 09:20 PM
rstoughy's Avatar
rstoughy
Cheers Guys, PF working at its best again
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
