Escos RS500 Cooler Vs Standard Charge Cooler ???
Post Miester !
I am trying to decide if i should fit a RS500 Style Cooler to the Escort,
but it has put out a good power as it is, Are they much better than the
standard kit ??....
Al...........
standard kit ??....
Al...........
well ive heard that crage coolers arnt to clever after about 350bhp on my car i went from a standard intercooler to the rs500 it made ahuge difference and the charge temp was so so much lower
I've got a Pro-Alloy one on mine now, seems to be a considerable improvement over the std chargecooler, and I'm confident that this will still be the case when the warmer weather comes.
Mines stage 3 and i fitted a rs500 cooler from radtec. now peaks at 25psi and holds 22/23 psi. Felt a better response when fitted and allowed us to up the boost a tad. charge temps much lower also
Plus it looks ace
Plus it looks ace Thread
