rolling road
Old Mar 2, 2006 | 03:07 PM
Reece's Avatar
Reece
Default rolling road
reit i live in wombwell near sheffield and need a good roolinroad to set my 2wd saph cossie up any ideas???
Old Mar 4, 2006 | 12:11 AM
wildheart's Avatar
wildheart
Dont waste your money on getting it set up on the rollers.
Get it set up on the road under the conditions that it will actauly be used.
I'd recomend NMS who are opening new premises close to Derby very soon
Old Mar 4, 2006 | 08:09 AM
cossie604's Avatar
cossie604
I'd wait till summer tbh, the charge temps will be more realistic as in you'll prob use it harder in summer and if it was set up around winter with much lower temps you may be getting det come the summer heat
Stu.
Old Mar 4, 2006 | 07:44 PM
wildheart's Avatar
wildheart
Not the case when the mapper in question knows what they are doing
Old Mar 4, 2006 | 08:31 PM
cossie604's Avatar
cossie604
Then it would just be a compromise of a given situation ie play it safe just in case
Old Mar 5, 2006 | 12:56 PM
wildheart's Avatar
wildheart
Any good mapper will allow for any small changes for safety.
And i know a man who may able to sort you out with a pair of kickwell panels,Doug from the Derbyshire group
Old Mar 6, 2006 | 07:36 PM
Reece's Avatar
Reece
sorry if this sounds stupid but wot are they (kickwell panels)???
Old Mar 6, 2006 | 08:19 PM
cossie604's Avatar
cossie604
lol sorted for kickwell panels Kris (cheers TF Rallysport ) and also sorted for headrests (cheers Spadge ).
Reese: the kickwell panels are the square-ish shaped bits of trim next to your feet that alot of people cut to fit speakers into...I cut mine (stupid boy that I am, shall cut off my left hand as punishment) to do just that some yrs ago but now ive bought a cage, the door bars foul on the speakers as they run tight against the panels hence the reason for needed replacements.
Stu
Old Mar 6, 2006 | 08:34 PM
Reece's Avatar
Reece
so there th plastic bits mine are ok then not bein cut
haha tidy
Old Mar 6, 2006 | 11:25 PM
wildheart's Avatar
wildheart
Mine got taken out to save weight lol.
Now live at Doug's
boeb
Jan 9, 2020 05:11 AM
mk22door
23
Oct 2, 2015 10:06 PM
AJC
Oct 1, 2015 06:47 PM
Mikersturbo
Sep 27, 2015 07:43 PM
