BAD MPG
Old Mar 1, 2006 | 10:09 PM
Rhys's Avatar
Rhys
Default BAD MPG
Right normally the Passat TDI is good on fuel getting around 200mils to £20. But this time its terrible only doing 150 What could cause it to change so much, driving is not different to normall etc. Could any sensors be playing up? Or forcourt robbed me?
Will keep eye on it But for someone who drives like miss daiesy most of time to get good MPG this is a shocker
Old Mar 1, 2006 | 10:12 PM
rapidcossie's Avatar
rapidcossie
wouldnt want to scare you with my mpg on te cossie rhys
Old Mar 1, 2006 | 10:14 PM
Rhys's Avatar
Rhys
lol mpg on my cossie is shocking norm get about 60miles to
£20 But suppose u dont mind tooo much when you can do ten zillion miles an hour. But the Passat bought for good MPG
Old Mar 1, 2006 | 10:31 PM
rapidcossie
your right mate..
the flames kinda make up for the bad MPG
Old Mar 1, 2006 | 10:43 PM
zaki's Avatar
zaki
you might find itl get better when the weather warms up
Old Mar 1, 2006 | 10:58 PM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
Glad I had the Bora TDI, it did 260 miles on £20!
Sarah
Old Mar 2, 2006 | 07:41 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
My bora does around the 200mile mark on £20. It gets worse when the weathers cooler & improves once its warmer. Also you've just fitted your 18"s havent you - I found MPG dropped once I'd fitted mine also!!!
Couple of things to try tho is the Engine Temp Sensor and/or the MAF unit.
Old Mar 2, 2006 | 09:05 AM
Rhys's Avatar
Rhys
SArah i dont know how u managed that, thats over 50mpg at today prices
Lee yeah been doing few 200 miles to £20 with 18"s on, might just be down to cold weather we been having last week. Will keep eye on it though if doesnt improve will find someone to plug it in to diagnostics
Old Mar 2, 2006 | 09:09 AM
Jonzy's Avatar
Jonzy
How olds the passat mate, ive got vagcom and a cable if you need to have a looky at whats going on.
Old Mar 2, 2006 | 09:11 AM
Rhys's Avatar
Rhys
Its a 52 plate mate
Old Mar 2, 2006 | 09:15 AM
Jonzy's Avatar
Jonzy
Wouldnt be a problem, 10 mins work.
Old Mar 2, 2006 | 09:26 AM
R4N SS's Avatar
R4N SS
my mondeo TD gives proper shit fuel economy - i only get around 140 miles to £20 quid.
When i bought the shit-tip in Sept/Oct I was getting 550 miles to a tank (£60 quid) and now im only seeing 430 miles (half of which was on the motorway).
whats causing this - surely it cant be the weather causing it to fook up this bad
Old Mar 2, 2006 | 09:31 AM
Rhys's Avatar
Rhys
Jonzy cool cheers mate, i will see what its like next fill up and see if its the same. Be good to plug it in though to see if all is well. will drop u pm
Ran i know sometimes they suck! I could get nearly 50mpg at 80mph watching how im using the loud pedal. But last night i was stuggling to get 40mpg
Old Mar 2, 2006 | 09:46 AM
Jonzy's Avatar
Jonzy
Rhys, if theres something wrong - duff sensor etc, the ecu will drop into 'limp mode' but wont always throw a diagnostic light. The software I got can read the faults stored, usually telling you exactly whats wrong. Can then clear the faults and all will be well.
Old Mar 2, 2006 | 11:30 AM
zaki's Avatar
zaki
id also check if theres an air leak anywhere and check your tire pressures often as they will drop pressure more and quicker in this cold wheather
Brickhouse
14
Oct 3, 2015 07:28 PM
Fordmad!
Sep 29, 2015 07:03 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
