snapped cam-part 2
just fitted the new cam and did a compression test
no1 140psi
no2 140psi
no3 120psi
no4 120psi
at first no 3 and 4 were only showing 90psi,but after starting it for 30 secs and then doing another comp test it gave the above results.whilst running i pulled no 4 lead and it made a massive difference and same with no3.
so it looks like i may have been lucky,although it does sound a bit tappy,
ill build it all up tomorrow and take it out for a little run.
no1 140psi
no2 140psi
no3 120psi
no4 120psi
JoeyBoyden
14
Aug 15, 2015 09:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
