s2 brake pad question
Old Jul 26, 2004 | 12:38 PM
slowpoke's Avatar
slowpoke
Default s2 brake pad question
ordered some pads and discs last week for my dads series 2
got them today tarox pads but they have the wires coming out of the pads for the wear meter
is this right i didnt think the series 2's had them on the brakes ?
cheers............matt
Old Jul 26, 2004 | 12:41 PM
Oranoco's Avatar
Oranoco
Don't think any of the S2's came with pad wear indicator. S1's did though
Give the company you got them from a bell they should explain things or sort you out the correct part if they have been supplied wrong. Even the best of us drop clangers from time to time
Old Jul 26, 2004 | 12:44 PM
slowpoke's Avatar
slowpoke
are the pads the same ie can we just cut the wires off ???????
understand tho its best to ring them up
cheers................matt
Old Jul 26, 2004 | 12:55 PM
Jim Galbally's Avatar
Jim Galbally
yes just cut the wires off and dont worry about it... a lot of places make em all with the wires on em as its easier than making 2 seperate sets for the cars with/without wear indicators
check theyre the right pads before doing this as if they sent you some for a different car completely youll be a bit fooked just compare them to your old ones, easiest way
Old Jul 26, 2004 | 01:06 PM
Stu.H's Avatar
Stu.H
yes mate, all the pads ive bought for s2 have the wires
once uve confirmed they are right size, cut em off
Old Jul 26, 2004 | 01:10 PM
slowpoke's Avatar
slowpoke
thanks guys i thought they would be s1 pads i said to my pops just to lop em off when he is changing them
should i say when I am changing them
cheers everyone.............matt
p.s are tarox pads and discs any good ?
Old Jul 26, 2004 | 01:14 PM
sm's Avatar
sm
yep just cut em off the reason they have em is because the s2 uses xr4i brakes and they have a brake pad sensor
cheers kev
Old Jul 26, 2004 | 04:21 PM
slowpoke's Avatar
slowpoke
ok gonna do the discs and pads tommorow
is there anything i could do with knowing ie changing them ?
any certain way of doing it ?
how long to change the discs and pads both sides please ?
cheers...............matt
Old Jul 26, 2004 | 05:51 PM
slowpoke's Avatar
slowpoke
BTTT
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
focus2351
Sep 9, 2015 09:33 PM
