running lean???
Old Feb 28, 2006 | 02:11 PM
barry0777's Avatar
barry0777
Default running lean???
ok fellas my rst running very lean just want to rix up the mixture a bit wanna know witch way to trun the screw in or out to rich it up a bit its also not going on to full full boost is this why???its off to the rollers fri so ineed to drive it there safley!!!!thanks
Old Feb 28, 2006 | 02:57 PM
320 bhp's Avatar
320 bhp
just leave it to the tuners mate just drive it steady and you wont have a problem
Old Feb 28, 2006 | 03:56 PM
addiction's Avatar
addiction
as above,just nurse it to the tuners and let them do it
Old Feb 28, 2006 | 04:56 PM
barry0777's Avatar
barry0777
ok will do leave her home tonight just dont wana mess her up as shes just had a rebuild etc etcthanks for the addvise thow chears
Old Feb 28, 2006 | 08:46 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
just a sugestion but have u checked all vac hoses for1 would cause it to run lean and if its in the vac hose to actuator will cause the actuator not to full open
just double check every thing
how do u know its running lean,do u have a wide band???
hope this helps
Old Mar 1, 2006 | 08:07 AM
barry0777's Avatar
barry0777
have cheaked vac hoses and it dose have a bleed valve will this couise under boost also iknow by this becouse a road tested it and ipoped the bonnet etc and the exh man was glowing red???i assume it lean that why i wanted to rich her up,too much is alway better then non ah chears thow matey
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
