Cossie management
Old Feb 27, 2006 | 10:46 PM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
Default Cossie management
Do you need ALL this stuff for cos management?
Loom Cosworth 2wd
ECU Cosworth 2wd
Throttle Body Cosworth 2wd / 4x4
Idle Valve Cosworth 2wd / 4x4
Ignition Amplifier + Heat Soak 2wd / 4x4
Crank Sensor Cos (Now Phase Sensor) 2wd / 4x4
Throttle Position Switch Cosworth 2wd / 4x4
Fuel Regulator Cosworth 4x4
Water Temperature Sensor Cosworth 2wd / 4x4
Charge Air Temp Sensor Cosworth 2wd / 4x4
Injectors STD Cosworth 2wd / 4x4
Map Sensor 3Bar
Bottom Pulley Washer
Throttle cable bracket & ISCV clamp
High pressure Fuel connections and lines
Water Temperature sensor converter
OddKidd Creations BASE MAP
Air Charge Temp sensor converter
Throttle Linkage
Phase Disk
Stainless Steel Top Sensor Bracket
BOTTOM PULLEY TRIGGER RING
Inlet Manifold Fiesta / Escort EFI (Mk 3,4,5)
Alt Bracket + Tensioner + Bolts
Bottom pulley
Map Sensor Bracket
Fuel Filter Bracket
Pectel Board + Plug for fitment
Top Pulley
Rocker Cover
Throttle Cable
Fuel Filter & Bracket, High pressure connectionsm Rail feed
Crank pickup sensor bracket
Fuel Rail Fiesta/Escort EFI + Bolts
Inlet Manifold Gaskets x2
Bottom Crank Sensor
Alternator
Inlet manifold bolts
Throttle Body Gasket
Rocker Cover Gas
Alternator Belt
Old Feb 27, 2006 | 10:56 PM
a11ova's Avatar
a11ova
think you have pretty much covered it there fella
Old Feb 27, 2006 | 11:02 PM
P_is_for_Paul
Coldo loves seamen
Feck me thats a lot of stuff
Tok the list off Janos pricelist, didnt think there was as much work involved
Old Feb 27, 2006 | 11:03 PM
a11ova's Avatar
a11ova
not an easy job mate, but well worth the benefits
how much you paying for it?
Old Feb 27, 2006 | 11:06 PM
P_is_for_Paul
Coldo loves seamen
Na not buyin it just now, just lookin at it for future if im keepin the S2
Old Feb 27, 2006 | 11:10 PM
JimmyBoy's Avatar
JimmyBoy
I think there are better management options for the s2.
Old Feb 28, 2006 | 09:45 PM
P_is_for_Paul
Coldo loves seamen
What ones are better and if so why? The only reason i want rid of the KE is to get rid of that shitty metering unit. Caused me so much bloody problems and there getting hard to get decent ones
Oh yeah and chatter
Old Feb 28, 2006 | 10:09 PM
JimmyBoy's Avatar
JimmyBoy
I think any of the modern management systems would be fine:
Motec
omex
dta
pectel
megasquirt
http://www.escortrsturbo.co.uk/forum...howtopic=11819
http://www.escortrsturbo.co.uk/forum...p?showforum=55
Old Feb 28, 2006 | 10:12 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
or theres gotech ???
still quite new on the scene , jamsport are sole distributors so have to speak to them
Old Feb 28, 2006 | 11:47 PM
EssexMikeSi's Avatar
EssexMikeSi
that list seems about right yea. most bits can be bought off ebay etc or people breaking cossies etc so some can be had for peanuts, but ya still lookin at a good Ł1500 upwards to do it properly
Old Mar 1, 2006 | 02:15 AM
Combi_Chris's Avatar
Combi_Chris
dont buy a 2nd hand loom either
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
