Urgent question from radders, what does CVH stand for?
PMSL, well impressed at you bothering to go into the garage at this time of year and freeze your tits off just to help radders out
His reply was "what the fuck does that mean"
Does he want to know what it means?
The letters CVH denote a particular type of 4-cylinder internal combustion engine produced by the Ford Motor Company during the 1980s and 1990s.
The CVH (Compound Valve angle Hemispherical combustion chamber) engine was introduced by Ford in 1980 in the third generation Ford Escort. It was later used in the Ford Sierra as well as the second generation Ford Fiesta. Engines were built in the Dearborn Engine Plant for the North American market, and in Ford's then-new engine plant in Bridgend in Wales for the European market.
The engine was originally conceived in 1974 and is unique in terms of its valves mounted at a compound angle, which allows for a hemispherical combustion chamber shape without using a more expensive twin camshaft arrangement. It also featured hydraulic valve lifters, a first for a European Ford engine.
A high-performance version was devised for 1984 with electronic fuel injection and a turbocharger.
Throughout its 20-year production life, the CVH had a reputation for being harsh and noisy at high speeds, and for its lubricating oil to sludge prematurely. Timing belts frequently failed about 60,000 to 90,000 miles (100,000 to 150,000 kilometres).
The engine was produced in many different capacities from 1.1 to 1.9 litres, the smaller versions being exclusively for the European market
mk3ste
Oct 17, 2021 10:09 AM
