Front Diff and Transfer Box Oil for Esc Cos??
Old Feb 27, 2006 | 03:59 PM
FletchCossie's Avatar
FletchCossie
Default Front Diff and Transfer Box Oil for Esc Cos??
Which oil do I use in the front diff?? And iirc is it Automatic Transmission Fluid for the transfer box on an Esc Cos??
Old Feb 27, 2006 | 04:01 PM
xr4x4rs's Avatar
xr4x4rs
dont know about the front diff as theres that many grades for diffs nowdays
but yes atf for the transfer box
for the box itself i use a comma mt75 as its designed for the gearbox
but oilman will be the best bet to ask
Butch.'s Avatar
Butch.
75/90w in front diff and the gearbox and atf in the transfer box
Old Feb 27, 2006 | 05:42 PM
FletchCossie
Cheers lads, will use Silkolene 75w/90 in the box and diff as I can pick it up locally
Old Feb 27, 2006 | 07:22 PM
JayB's Avatar
JayB
A up mate, hows the old girl going . From what I can remember the DPE gearbox/transfer box is mono lubed. They drilled holes through the gearbox housing into the transfer box due to the gearbox pressurizing and pushing the oil into the transfer box and the oil couldn't return back to the gearbox.
Jay
Old Feb 27, 2006 | 08:04 PM
FletchCossie
Jay mate, how's it going??
When I changed the box last year I filled the transfer box and gearbox up seperately, so don't think they done this mod to me new one?? But the gears are crunching every now and again, but clutch is almost dead. So gonna change clutch and make sure box has new oil in and see how she goes But the box has had a hammering in the past year
Changed front diff, box and rear diff now
Old Feb 27, 2006 | 08:13 PM
JayB's Avatar
JayB
Im good cheers mate.
They must have sorted the breather system out then, as I had several gearbox failures until they mono lubed the gear/transfer box. Never had a problem after that. Might be worth giving Pete a call.
So you've killed the front diff too LOL. That was the original one, so its lasted well really. are you going for an uprated diff now?
mk22door
49
Mar 26, 2022 07:15 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Chas
Sep 21, 2015 08:57 PM
st220kyle
16
Aug 14, 2015 06:13 AM
track.focus'd
Aug 12, 2015 05:53 PM
