metal fuel line for a escort cosworth were from
metal fuel line for a escort cosworth were from .been down to my local hydraulic shop they have metal tube flexible like brake pipe its copper nickel I think will fuel be ok .or is there an affect the. bore size is the same
Just won some Ford metal fuel pipe on ebay last night and hasn't arrived yet (obviously!)
Should be 6mm OD and 4mm ID, but will need the appropriate fittings on each end. I assume the Cosworth stuff will be the same?
