t34 turbo housing
Old Feb 26, 2006 | 11:08 AM
DAN P's Avatar
DAN P
Default t34 turbo housing
does any body no what is the best way of turning the housing around so it will fit my 2wd ? thanx for any help pics would help to lol
thanx for any help
Old Feb 26, 2006 | 11:11 AM
Rick's Avatar
Rick
the best? there's only one way.
u have to slacken each of the 12 nuts which clamp the housings to the core (6 each side) and then rotate them. The compressor will move pretty easy, but the exhasut housing will prob need a lot of persuation.
Old Feb 26, 2006 | 11:15 AM
dave cos4x4's Avatar
dave cos4x4
just undo the bolts on the housings and turn.
it will be dificult to get a the bolts etc.. but it can be doneyou may need to use the bolts to force open the housing a bit so it may be easier to spin.
just remember to keep the oil feed in the same place and spin both ends.
have you another turbo to see where to line up the housings,may help you.
Old Feb 26, 2006 | 11:17 AM
The DIVA's Avatar
The DIVA
Be VERY careful you dont fuck the exhaust blades when you attempt to free off the housing,use a bolt each side to push the housings apart equally or you will damage the blades if you do it incorrectly..
Old Feb 26, 2006 | 11:19 AM
Rick's Avatar
Rick
diva talkin from experience?
I oxy'd mine in the end - rispec
Old Feb 26, 2006 | 11:20 AM
DAN P's Avatar
DAN P
i have my old t3 ? if thats any good i have undone all the bolts and its being a bitch
Old Feb 26, 2006 | 11:21 AM
The DIVA's Avatar
The DIVA
Just the experience that comes with building over a hundred turbo`s mate...
Come to think of it i`ve built about a hundred of everything now with you fookers..
Old Feb 26, 2006 | 11:23 AM
DAN P's Avatar
DAN P
this sounds like hard work i think im to heavy handed for this
Old Feb 26, 2006 | 11:26 AM
The DIVA's Avatar
The DIVA
Just be patient Dan........use the bolts to ease the housings apart,just try and keep em fairly straight........once you got it apart you can clean up the housing join so it spins freely,they are not mega delicate you just need to avoid any bending of the exhaust blades..
Old Feb 26, 2006 | 11:29 AM
DAN P's Avatar
DAN P
lol nice one m8 will go have a go or i think my old man can do it lol be brakes it he buys it
Old Feb 26, 2006 | 11:30 AM
The DIVA's Avatar
The DIVA
Old Feb 26, 2006 | 06:01 PM
Ginge !'s Avatar
Ginge !
just finding my feet
why does it need to be turned,,,,,,,,, are they facing another way when standard then
oh and on the subject if removing housings i managed to pull my compressor housing off mine when all bolt where undone VERY easily,,,,,, should i be concerned
Old Feb 26, 2006 | 06:12 PM
bud-weis's Avatar
bud-weis
Football Cwazy
could be loose from vibration ( lack of damper or worn shaft ?? )
and yes on a standard escos the housings are at a different angle
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
jaimesdna
Aug 25, 2015 06:59 AM
Danielbetty
Aug 23, 2015 12:52 PM
