My S2 just died
Feb 26, 2006 | 11:06 AM
My S2 just died
Driving along and it just died like the fuel had run out. I managed to start it again and 5 mins down the road done it again and couldn't start
I put a new fuel pump on not that long ago so is there anything I should be looking for other than the wiring to the pump??
Please help, thanks
Feb 26, 2006 | 11:10 AM
Does it prime the pump when you turn the ignition on?
if not, it might be the relay under the dash,not sure of the relay colour though,
Feb 26, 2006 | 11:11 AM
it didn't once it just died but haven't checked since. will go have a look.
Any one know what colour the relay is??
cheers
Feb 26, 2006 | 11:20 AM
The relay is pink. Above the accelerator pedal.
You sure its got fuel in it.... the fuel gauges are notoriously dickie!
Feb 26, 2006 | 11:23 AM
I just put 20 quid in and done 10 miles then it happened
I def put unleaded in also
Feb 26, 2006 | 11:25 AM
Defo sounds like the Relay,as said above-A kind of pinky/purple colour and about Ł20 odd quid from Ford
Feb 26, 2006 | 11:28 AM
There is a way of bridging the connections without the relay being there,but again i dont remember as its been along time...
Feb 26, 2006 | 11:35 AM
Yeah just checked my relay burnt out and melted
So 20 quid from ford??
How do I bridge it cause need car tomoz and ford aint open now.
Cheers for helpin finding out prob - now just to fix it
Feb 26, 2006 | 11:40 AM
where abouts in essex are you?
if you are near or can get to southend could try ken-lees down hamlet court road there open till 10pm tonight
Feb 26, 2006 | 11:41 AM
Feb 26, 2006 | 11:43 AM
Up near cambridge so bit of a treck with no car.
I ripping apart the relay now see if I can work this thing out if its not too burnt inside
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
