help with mk6 escort zetec si
Old Feb 25, 2006 | 09:01 PM
AKJ-Dan's Avatar
AKJ-Dan
Default help with mk6 escort zetec si
Got a slight problem when accelerating low down in any gear, its like its misfiring and chugging real bad up until about 2.5k revs but its had all the plugs and leads changed etc etc, a local mechanic thought it might be the crank shaft sensor so had that changed. Still no luck
Any ideas?
Old Feb 25, 2006 | 09:08 PM
TrickyDicky's Avatar
TrickyDicky
Default Re: help with mk6 escort zetec si
Any ideas?
i'd try the lambda first then if that doesnt cure it swap the airflow meter, try that-if you've got a mate with an escort or mondeo just borrow his to see if it improves any.
hth
Tricky
Old Feb 25, 2006 | 09:10 PM
AKJ-Dan's Avatar
AKJ-Dan
Cheers tricky, ill get them checked.
Old Feb 25, 2006 | 10:00 PM
filthyrichie's Avatar
filthyrichie
did u use ford plugs ?
if not fit them first
coil unit after that i recon
Old Feb 25, 2006 | 10:01 PM
luke89's Avatar
luke89
Team HOTHOT!
if its a 1.6 and u need a ecu i got a 1.6 ecu out my fiesta si also got a MAF and a laber thingy in the pipe of my si lol should be able to send any to you just to try pm me if u want any
Old Feb 26, 2006 | 09:21 AM
AKJ-Dan's Avatar
AKJ-Dan
filthyrichie
yes mate, pretty sure they were ford plugs ran fine with what ever were in there for a good few months anyway
luke89,
cheers mate, ill keep that in mind and let you know if i need anything or not
Old Mar 9, 2006 | 07:58 AM
Chipperx2's Avatar
Chipperx2
Funny that, mines doing the same, and I also though about the coil pack, but being Ł60 from Ford made me think twice, just incase its not lol. My plugs were quite black, as if it was running rich. So I'm gonna clean them up today and see if anything happens.
Old Mar 9, 2006 | 08:47 PM
Chipperx2's Avatar
Chipperx2
I also have a spare Ignition Coil if you want one, used, but its genuin Ford
Old Mar 9, 2006 | 08:56 PM
Zetecfiesta's Avatar
Zetecfiesta
id just say the maf mine did this until i cleaned it
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Ethan sagoo
Aug 25, 2015 03:22 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
