18's on a 2wd?!...
Old Feb 25, 2006 | 07:56 PM
maxest's Avatar
maxest
Default 18's on a 2wd?!...
Whats the best offset for 18" wheels on a 2wd saph?!...
Would 8x18 et25 fit ok?! Would coilovers be needed for the front?!
Tyre size would be 215 35 18....
Thanks
Old Feb 25, 2006 | 08:16 PM
boost mad's Avatar
boost mad
ive got 8x18s 42 offset with a 5 mm spacer.
running 215/35/18s on a 2wd saph
Old Feb 26, 2006 | 10:32 AM
maxest's Avatar
maxest
Are you running coilovers?!...
Anyone else?!...
Old Feb 27, 2006 | 11:21 AM
sierra4x4tbo's Avatar
sierra4x4tbo
Default Re: 18's on a 2wd?!...
Thanks
ET should be closer to 35 than 25 on 8" wide wheel. No need for coil-overs when using 215/35/18 tyres. If you go for 225/35 tires, coil-overs might be in order, otherwise it could be tight fit.
I have 8x18" et35 on my Cossie. Ok it's 4wd but one of my friends has the same size rims whith same et on his 2wd Cossie.
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
arfurski
Sep 26, 2015 10:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
