Big rear disc conversions...
Whats the biggest big rear disc conversions you can get utalising standard calipers?!...
Is it Mike R's 300mm ones?!....
I'm sure i heard in the past Hi-Spec do 330mm one's?! Had a quick look and can't find their website?!..
Thanks
Max
Thanks
Max
Guest
Posts: n/a
Thanks
Max
Thanks
Max
Thanks
Max
Thanks
Max
Found there website now anyway, so i'll bell them on Monday!
Originally Posted by kelcos
Max, i popped into Hi Spec to enquire about there rear disc kits a few weeks ago.
they do both the 300mm & the 330mm kits.
if i remember correctly the 330 kit was £470.
HTH
HTH
think 300 mm on standard calipers are fine,any more and you will just need a bigger calipler bracket.
don't think you need to go more than 300's if you only have 330mm fronts.
Also, regarding the spare wheel, you MUST not fit this to a car running 18s, as the rolling radius is completely different (desined for the standard wheels) and it will muller the diff trying to turn at different speeds for any kind of distance.
Thanks for the advise
Also, regarding the spare wheel, you MUST not fit this to a car running 18s, as the rolling radius is completely different (designed for the standard wheels) and it will muller the diff trying to turn at different speeds for any kind of distance.
Ram raider.
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
. Beware!
