***car stolen - Mitsubishi Evo VIII FQ MR 340 ***
This car was stolen yesterday evening from a frined garage at around 6:50 pm from a garage in Brixham, South Devon.
The car is gun metal grey with standard alloys etc.
I know the chances of finding this car are slimmer then normal wich is next to non but its worth a chance
There is a small pin dent about the FQ Mr 340 Bage on the boot panel
Cheers All
(not sure where this should go mads so please feel free to move it to where ever is best)
Cheers All
Originally Posted by B8
this car should have tracker retrieve as standard??
My insurance insists I have Tracker, luckily it was on my car when I bought it.
Feel sorry for the owner
Euan Gunmetal grey is the best colour for an Evo IMO, would have liked mine to be grey.
Leather and Navigation (Which uses Rac Trackstar as a hub) being the only other difference from the MR320 other than power.
If ya gonna get a tracker fitted then dont use RAC....simple as
Imports?
Im unsure where you get that the above car is an import? Maybee the MR & FQ thats causing confusion?
MR FQ340(in this case) is indeed an imported car which Mitsubishi UK (CCC) have modified and sold through UK dealer networks.
The MR FQ340 having Smartnav/Rac Trackstar as standard.
It's what is called a 'grey' import, you can tell by the foglight in the bumper. My car is a 'grey' import too. Not imported by CCC to make it a UK spec car to be sold through Mitsi dealers, but imported by A.N. Other.
Redkop the fact that the car has the foglight in the rear bumper proves that it is a UK car. Imports do not come with a foglight hence why you see jap cars with the "after thought" fog light stuck under the bumper to pass SVA test when imported. Also import MR's were only in 280 and 310bhp variants.
The car is definitely a UK car. Hope this clears the debate up.
Ollie
Ollie
Ollie
Ollie
My UK Car is exacty the same at the rear, see pic below.
Mike
Incorrect. My car was imported into the UK in Sept 2003, look where the foglight is... it all depends on where the importer chooses to put the foglight when going for SVA. UK cars from the the 7 or 8s onwards have the foglight incorporated into the rear cluster replacing one of the reversing lights.
I am still pretty sure you will find that the import MR's only came in 280 and 310 variants. I found this as i nearly bought one before i found my 6.
I can hpi this car in work on monday though.
tracker has no signal at present, has been sighted racing on single lane roads in torbay up to friday night so should hopefully still be in the county at least
Just goes to show that even modern car alarms are a heap of shite if the crim is clever!!
Sincerely hope you get it back
