4 ingredients will EQUAL fast....ADDING PICS AS I GO.
I dont think the MAD camp what to play
T4 turbo,i have decieded to stick to a PROPER one,no arsing about with mods and reliability issues...just touring car style....a solid 500plus BHP on pump fuel is deffo on the cards combined with high compression,well in the sense of using this turbo and 32psi flat till 8000rpm!Torque should go around 430ft lb....not major because i cant run a boost spike due to comp ratio.....if i could a 40psi spike like a low comp then 480 ft lb is a reality,but i settled for drivability
7.9-1
This is DIY.
Steve....i am leaving Karl to sort that part so dont ask me his email is karl@norrismotorsport.co.uk ...
Yes the escos is staying around 370bhp with ALS as its awesome and i beleive within the std drivetrains ability (road car no launches!)
This is DIY.
Originally Posted by Itsmeagain
So you reckon your gonna be able to run 32psi held at that comp (7.9:1 right?) on pump gas?
Without retarding the timing so much that youd be better off running 25psi and more timing?
I've already told him it will need to be more retarded than he is
Originally Posted by Bosch-Man
Take one Sierra Sapphire:-
Add this highly specced DIY YB:-
Then add this turbo:-
Then add:-
Then add:-
sounds good phil
I want excellent off boost drivability as well, not a top end screaming lag-monster, so I will be very interested in this as I am looking to run 8.5-1 on a GT35, so will be good to see how yours turns out. What pistons are you using? When is the mapping due to happen?
And thats why all these high comp jap turbo lumps aint got any.
cheers jay
No dyno figures as that isnt a true figure
I thought NMS's used the arse dyno?
Steve you have it all wrong on why i am higher compression...the boost wont come in till 4k similar to a GT35 one so below this on low comp it will be flat as a fart i know i been there trying to pull out of junctions!!!This more std comp will drive like a std Cossie...lovely.
Aduz i am both
Aduz i am both
Guest
Posts: n/a
Aduz i am both
Aduz i am both
Engine dyno give a good idea what you should have. So get it to the engie dyno
Wil....i was going your route (gt35)....BUT the maximum you can run on pump fuel will be around 550bhp...so i looked at my comp ratio and bought what i thought was the best turbo for the situation...the T4.As its only a road car i wanted power/reliability/drivability.....Although the GT35 would bring the same kinda results as the T4 it is more unreliable,needs much more attension,plus is a right arse to fit and more expensive plus have the ability for xtra bhp i just cant use.
IF however you plan to use race fuel then GT35 that ass
Guest
Posts: n/a
Yum...why is the MAD camp so against everyone even in there own camp?Isnt your mentor Rodney famous for saying...Brunters is where the bullshit stops?NOT the dyno!
Think if your looking for over 400bhp then the engine dyno is the way to go and phill l was wishing you luck so what the hell.
Yes getting the dyno figures to do the same in the car is where the bull shit stops like taking it to brunters. Or getting it timed anywhere apart from the M1(DINGY)
Dyno figures can be printed to show any amount of power that why l desided to get Performance Ford to take my car to brunters to prove all the people that didnt belive see my figures.
Have a good day
