Valves for High power Engines?
Old Feb 24, 2006 | 12:13 AM
Chris S's Avatar
Chris S
Default Valves for High power Engines?
Big Power Valves? 1 piece steel??
what are the options for valves??
heard alot about the heads dropping off standard 1's,
what are my options?? +1mm oversize?
will be having some headwork done on 1 of my heads and should imagine he'll need the valves. so need to buy some soon.
i dont mind buying things that are needed, but do i really need them?
Old Feb 24, 2006 | 12:25 AM
For anyone who isnt aware, the standard valves he is referring to on his engine are two piece ones with a sodium filling.
The 1 piece steel ones he is referring to are straight 21-4N valves, as opposed to nimonic80 or anything fancy like that as they arent really available (well not for sensible money)
Things to consider are, fairly high rev limit on his engine, like 8Krpm
Lots of heat in his engine, its running lots of boost and will probably be on gas at some point too.
Old Feb 24, 2006 | 10:18 AM
Chris S's Avatar
Chris S
thanks for that chip, ive searched but not come up with nothing.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Churtz
15
Aug 13, 2015 06:40 PM
