no dash lights on escort rst
Feb 23, 2006 | 10:12 PM
ive just fitted a new engine into my escort
went to fire it up but had no dash lights what so ever, no batt,no oil,no handbrake
anyone got any ideas what this could be as im stuck now lol
was ok 7 months ago when i stuck it in the garage
Feb 24, 2006 | 11:26 AM
btt
anyone have any ideas
checked all the fuses
Feb 24, 2006 | 11:44 AM
Is the rev counter / speedo / temp / fuel gauges working?
Did you remove the clocks as part of the engine change at all?
Feb 24, 2006 | 12:07 PM
everything else works
didnt touch the clocks alls i did was change an engine
just dont have the red ignition lights at all
Feb 24, 2006 | 12:21 PM
on the back of the clocks are two multi connectors. Is it possible one of them has been dislodged? Perhaps from the removal of the speedo cable?
Long shot, but its all I can think of.
Feb 24, 2006 | 12:35 PM
doubt it mate but ill check
the speedo cable never got touched just engine swap no gearbox
ill have a look more into it once i get the turbo fitted again
thanks
Feb 24, 2006 | 12:36 PM
Is your drivers side rear sidelight / brake light out? If so its a fuse.
Feb 24, 2006 | 12:39 PM
ill have a check of that in a bit asweell then
checked all fuses and seem to be ok though but ill double check
Feb 24, 2006 | 03:54 PM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
dlwarrior
Aug 5, 2015 10:19 AM
turbobill
Aug 1, 2015 08:55 PM
Old ford
Jul 31, 2015 06:50 AM
1992 ,
92 ,
channel ,
circus ,
concrete ,
cutters ,
dash ,
dont ,
escort ,
ford ,
lights ,
m3 ,
passionford ,
wont ,
work
