Wheel re-alignment - how is it done?
Ok, my fiesta's front wheels need re-aligned after i fitted the new suspension, its very easy to see on it that the front tyres are very "toe-out". I see Kwiffit etc offer the serivce for about £30 (don't know if this is for checking only or re-alignment), but what exactly needs to be done to make both wheels point straight? And will this cost alot of £30 do you recon?
£30 should be about right for a check and adjust.
Get it sorted as soon as you can as your front tyres will wear out at an alarming rate if its badly misaligned.
you can not realistically do it without gauges
a good freind of mine whos a race driver swears by a string
as a former employee of kwik fit , they check the tracking foc and if it requires adjustment they will show u or ask u if u would like it adjusting and its about 27.00 pound u can use other companys to do this but make sure they have the 4 wheel alignment gauges
Karl @ FPT
Sep 21, 2015 11:17 AM
Adam Graham
Sep 6, 2015 06:04 AM
