differences between saph cos and XR4x4
The Special One
What's the differences in the floorpan/running gear?
Is the XR weaker?
What are the differences in the brakes, I mean like the beams, not worried about the disk/caliper sizes etc?
cheers
Is the XR weaker?
cheers
front hubs and rear hubs are different
rear beams are the same, as are trailing arms, gearboxes are the same, altho different bell housing on the V6 XR4x4, rear propshaft is thicker on the cossie, alloyt front cross member is the same aswell
rear driveshafts are different, the flanges are thicker on the cossie,
front driveshafts are slightly longer on the XR4x4, but easily useable on the cossy, as i have done
The Special One
hmmmmm, thanks fellas
looks like something like this may be my new car then
http://cgi.ebay.co.uk/ws/eBayISAPI.d...3530%26fvi%3D1
The Special One
thanks again
now you didn't say pre-90 spec stuff
different rear arms, gearbox, diffs, driveshafts, props and everything - nothing the same as a cossie on that car apart from the front proshaft
anything 1990 onwards will do
and price for changing hubs over - depends where you get the parts, some people sell front knuckles (hubs) complete for Ł35 a pair, but they don't realise their value - which is nearer Ł200 a pair
The Special One
one like this maybe, it says '89 G, but looks like the later model to me?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...6420%26fvi%3D1
The Special One
The Special One
now this is 90-spec I'm sure. well, unless someone's changed the wheels, but it says 1990 anyway
http://atsearch.autotrader.co.uk/www...00608224985736
The Special One
is this a 90-spec?
I'm guessing no, but only 'cos of the wheels really
http://cgi.ebay.co.uk/ws/eBayISAPI.d...7382%26fvi%3D1
The rear arms are different as the cosworth versions have spherical bearings fitted where as the xr4x4 used rubber only - they are though physically the same - so not a problem if you are planning on poly bushing them.
The rear props are the same, its the 2wd ones which are thicker.
The casings of the 2 litre post 1990 MT75 is the same as a cosworth but the ratios are different, where as the ratios are the same as a cosworth on the 2.9 but the case is different.
The diffs on the 2 litre are 3.9 but 3.6 on the 2.9 ( same as cosworth)
The rear hubs/ bearing carrier are smaller on the xr as they use a smaller disc but the calipers are the same as 2wd cosworth
rear shafts are the same, as is the beam, but the arb is thinner
Front hubs wont allow cosworth 4x4 discs and calipers to be fitted and the rack has a bigger turning circle
mot failure 2 litre xr4x4 sell for around Ł200 but contain over Ł600 worth of usable spares so make a good donor for a cosworth project
the ratio on the cossie 4x4 box and the twincam 4x4 box are exactley the same - i know this as a fact, i have a twincam box in my taxi
also if you go for it get a 2.9 or 2l model as these are efi and most of the management just plugs up behid the battery
ive done this conversion years ago to my old one
alls i did was poly bushed it, changed the front and rear hubs to cosworth items so i could run cosy brakes
engine and gearbox are a direct fit as with everything else in the engine, even the holes for a 500 cooler
props are the same as well
took me 2 weeks on my own to do mine
the only bit that is a bit diefferent is trhe exhaust as its longer for the saf so the tail pip sticks out a bit more but hardly noticeable
also if you get a 2l model you will need to change the accelator pedal aswell as cables are different
Hub wise when fitting 4x4 cos brakes ( which I have!) to my xr4x4 do I need the hubs and the hub carriers?? ie the bit the wheel bolts to and the bit the strut goes into.
steve
steve
I thought the bit the strut goes into was called the carrier?
confused now, I think I need the bit the strut goes into, correct?
cheers for the help BTW,
steve
steve
sorry yes mate
bit tired didnt ralised what i wrote
you need the carriers the bit that the stut goes into yes
the drive flanges what the discs go onto are all the same if that helps better
worth the upgarde to be honest mate
as standard xr brakes are the same as s2 turbo at the front lol
im lucky enough to have aset but ill be using them for when the 24v goes in to it in a couple of weeks just carnt decide whether to have a 4 pot 330 or just run standard cosy brakes
I have the cos 4x4 calipers, disks just need the hub carriers now..
thanks for the info I am also going 24 v with mine over next winter so when you do yours tell us the story of how it went..
cheers,
steve
cheers,
steve
will do mate
will be doing a underside resto at the same time so will be a post in the resto soon
just waiting on another 4x4 to come so i can rob the bit soff it for transmission as mines just a 2L so parts arnt compatibale
Remember the XR steering rack although the same ratio as a cossie can a little further than a cossie which is restricted by about 0.4 turns or something and you do seem to get a grinding noise at full lock sometimes.
The Special One
http://cgi.ebay.co.uk/ws/eBayISAPI.d...romZR40QQfviZ1
that one is no good then either?
it says 1990, but january registered plus has 88/89-spec rear spoiler
it's the 2.9 though
it's the 2.9 though
The Special One
but then this one is regd 1991 and has what I thought was the earlier boot spoiler
http://cgi.ebay.co.uk/ws/eBayISAPI.d...4195%26fvi%3D1
fuck me i'm confused!
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
