no brakes!!
Hi all just a quicky set off to work this morn in my saph 4x4 got on the motorway tried to brake 4 my junction and no brakes! to say i shit myself is a understatement managed 2 stop on the handbrake luckly no cars on the sliproad got it to my mates house round the corner couldnt see any fluid leaks and still full in the res could it be an air lock or is it more likly 2 b the master cylnder any help would be great cheers
[/b]
[/b]
probably your abs relay is gone its located on the passenger side near your transmission tunel under the dash theres 4 or 5 relays there i think its the purple one mind you theres two purple ones but they are the same.
my mate gaz had the same problem with his 4x4 sapph fitted new relay and all was fine. cant believe a car with that much power has these problems
incredible!
hope this helps mate any more help just ask !
incredible!hope this helps mate any more help just ask !
