Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Boot lock problem on 1995 Ford escort s1 cabrio
Old Feb 23, 2006 | 03:54 PM
maxturbo's Avatar
maxturbo
Default Boot lock problem on 1995 Ford escort s1 cabrio
I've only have this car 1 week. Previous owner had problems with lock on boot. I am unable to open boot. Is there a special locking system for the boot on this car? I'm told to use red master key but still no luck. I have 2 other keys but same problem. How can I get it opened? Can I get in through back seat?
Old Feb 24, 2006 | 12:19 PM
ScORTED's Avatar
ScORTED
Project Money Pit
drop the back seats down, is the lock sticking or is the button sticking
Old Feb 27, 2006 | 07:55 AM
maxturbo's Avatar
maxturbo
I cannot open lock on boot door. Key turns in lock only, but i think lock mechism is stuck at bottom. I was reading car manual and you can only open rear seats by pulling a button in boot area with boot open. Any other way in opening rear seats?
Old Apr 25, 2006 | 11:24 PM
AlcoholicA's Avatar
AlcoholicA
excuse my ignorance, but I didn't know that there was a 1995 S1 cabrio?
apart from that - to answer your question.....
The seat on mk3, and mk4 and [presumably] later models only recline by using the seat release cable which is located in the boot of the car.
Old May 3, 2006 | 04:19 PM
escort cab's Avatar
escort cab
Default lOCK
I think he means Si not S1. I had troble with the boot lock before.
The only way to get into the boot through the cabin is to release the rear seats from the inside.
However you obivously cant do that.
you could however bend the rear part of the seat and reach in to get to the pull thing for the seats but it will reck them. (did this in a scrappy)
Maybe try unscrewing the seats though as if you were removing them.
I dont know if this helps - but i tried
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
