FAO All Secs Monitor owners :)
Team HOTHOT!
A lot of you may have noticed that once the display on the monitor has warmed up, it starts to fade out and you have to adjust the contrast for it to be seen properly again
Today I fitted a little modification to mine in the form of two 40mm cooling fans to keep a stream of nice cool air to the monitor - so far it seems to be doing the job, but will only be able to find out for certain on a long journey, in which I will post up results of the modification
These are the fans i fitted:
and i forgot to take pictures
My Pectel monitor does the same thing in the winter when I have the heater vents on hot, as it sits in the banana pod above the hose and the heat transfer causes this. All I have to do is turn the heating down and it comes back again. I think I will just do some sort of insulating dividing wall of some description.
Team HOTHOT!
Smit - took me about an hour as i had to piss about cutting vent holes and the like in my instrument binacle
its some small cooling fan, cost me £3.50 for 2 delivered on ebay - its 40x40mm and is approx 8mm in height
also silent in operation aswell
Nice one, mine is in the standard saff place (Where clock should be) and does fade ever so slightly when it gets hot. There's plenty of room behind the monitor so i reckon might be worth a mod if the problem gets worse
Cheers for ya help
Cheers for ya help
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
