Fans What do you think
Hello again Thanks to my mate Roy hes got the fans working
We had the car running but bottom hose was not getting warm so he put the old state back in after testing new one found to be faulty
One wire was a bad contact on fan switch he sorted that
All tested fine
Hes told me to take the new state back which ill do tomorrow
But the fans seem to only cut in on small fans just before it goes to the black line under the red and then takes it back down to half way
My mate still going to put the new state in once they exchange it and a fan switch to just in case thats why its cutting in so late
Even with fans cutting in so late the oil preasure still quarter of the way up so it cant be running that hot and no loads of heat hitting you in the face when you pop the bonnet
Any one else had a problem like this
Thanks again Roy
All tested fine
Thanks again Roy
Originally Posted by 330cossie
No probs m8.
Take the new thermostat back to the shop and
get another one and will see if that makes a difference.
I'll get it sorted rizla
Aint no one had this problem on there Escos
Originally Posted by cozzymatt
sure its the right temp sender mate?? make sure you get the right colour fan switch aswell..
Temp sender was bought from woodford's(gen ford)
so should be right
And as for the fan switch we've ordered one from ford's
who only list one switch for that model!
Just have to wait till the new thermostat and switch
turn up and go from there,fingers crossed all will
be ok.
so should be right
be ok.
the fan switch is done no change still cutting in just under black line before it goes into red
Oil pressure is still on quarter on idle when the fans cut in
Roy mate its the state now last result be here tomorrow
If not do as you say take the rad off and flush it
And as i say when the fans do cut in theres no major heat comming from engine bay when you lift the bonnet
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
