just crashed my saph cozzy :-(
just crashed my saph cozzy in a curb
lol done my new adj tca an bent the steering rod can the rod be changed or will i need a new steering rack
cheers
cheers
If I was you mate I would replace the complete rack just to be on the safe side.
I can remember when I crashed my old 2i into a kerb, thought the only damage I had done was the bottom arm. Replaced the bottom arm drove it around for a few days with no problems. Turns out I had also weakened the steering rack (no signs of external damage) and the rack snapped in two resulting in no steering at all, you could spin the steering wheel round.
Luckily for me it broke as I was setting off from the lights.
If it had snapped at 70mph
defo change whole rack m8
better todo that than have it snap when you doing sily speeds
happened to my m8 in his xr2 turbo he hit kurb slight bend thought it be fine moments after he slowed down from a 130mph blat he turned a corner got half way round then snap no steering very lucky
Russ Payne
Sep 25, 2015 08:29 PM
