nearside driveshaft
Old Feb 22, 2006 | 11:45 AM
saffi-andy21's Avatar
saffi-andy21
Default nearside driveshaft
fit new shaft yesterday as my original one broke the inner cv joint, was told was a common fault so replaced with a new one 10 mins down road it has done the same again
could this be the diff???
any replys much appreciated[/b]
Old Feb 22, 2006 | 12:50 PM
Spax's Avatar
Spax
Check your engine mounts mate, my mates Saph 4x4 did this a few time's before he realised
Old Feb 22, 2006 | 05:53 PM
escortrsmatt's Avatar
escortrsmatt
how low is the car?
Old Feb 22, 2006 | 07:06 PM
Smit's Avatar
Smit
The 60ft Launch King
Originally Posted by escortrsmatt
how low is the car?
If the car is too low with the standard CV joint the shaft will distroy it within miles...
GGR doing a 50% longer CV joint so it won't fall out...BTW it ain't cheap but mine is still ok after 5 years
Old Feb 22, 2006 | 08:31 PM
CosKev3's Avatar
CosKev3
Deffo check engine mounts
Had this prob on my old 4x4,the mounts look ok untill you jack up the engine
Mine just split into 2 pieces,both mounts
But as said above,if car is too low you will need longer shafts
Old Feb 22, 2006 | 08:49 PM
bigad4x4's Avatar
bigad4x4
Mounts defo mine did exactly the same buy yourself vibra-tenics cosworth mounts and xr4x4 shafts because they are longer
Old Feb 25, 2006 | 06:28 PM
Fezza__rs's Avatar
Fezza__rs
have you bought a ringer lol
Old Mar 3, 2006 | 04:32 PM
saffi-andy21
Cheers fellas.
I've had a look and it looks like the original shaft had already been swapped for an xr4x4 so i've sorted that with another 4x4 shaft, as for the mounts i haven't had chance to look yet so its stayin put till i've checked, what is it that i should look for.
Old Mar 4, 2006 | 09:59 AM
CosKev3's Avatar
CosKev3
Originally Posted by saffi-andy21
Cheers fellas.
Trolley jack under sump,jack it up slowly and watch the engine mounts split into two pieces
Obviously if it starts to lift the car up when your jacking up the sump the mounts are ok,but I doubt it
Nick 172 Sport
Sep 28, 2015 07:21 PM
mondeomark
Sep 28, 2015 06:28 AM
rsturbo27
Sep 5, 2015 05:08 PM
Mark Mawson
Aug 31, 2015 07:09 PM
markk
18
Aug 17, 2015 05:19 AM
